Go to Post edit: laptop. yeah as a programmer to not put this in I should be taken out the back and "decompiled". - Stuart [more]
Unread 08-02-2010, 15:32
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: help with LabVIEW framework
Originally Posted by kws4000 View Post
I also have a question:
When opening the compressor in the BEGIN sub-VI, what is the difference in the "Pressure Switch DIO Module" and the "Pressure Switch DIO Channel"?
I know they refer to different pieces of hardware (digital sidecar and pnematic breakout), but which one? Do I need to use both of them? What about the "Relay Module and "Relay Channel"?
Thanks
Each Module has a number of different channels on it.
The Pressure Switch DIO Module refers to which slot of the cRIO the module attached to the Digital Sidecar is in. The Pressure Switch DIO Channel refers to the channel number (printed in white on the Digital Sidecar) that the switch is attached to.
The relay module and channel are similarly defined.
LabVIEW framework realtime architecture Ether NI LabVIEW 2 07-02-2010 12:54
Help with basic algorithm on LabVIEW Manoel NI LabVIEW 26 14-11-2009 17:06
timer help with labview T3H_K3YM45T3R Programming 6 16-02-2009 18:34
Help with LabView daviamp NI LabVIEW 2 03-02-2009 19:55
Tank Drive with Advanced Framework in Labview finman NI LabVIEW 4 30-01-2009 13:35
