Go to Post However, the skill of calculating things by hand and sketching by hand is something that we should continue to teach the youth (until my netbook can run Inventor :D) - Zach O [more]
Unread 08-02-2010, 16:17
qpang qpang is offline
qpang is an unknown quantity at this point
example project Autonomous mode Watchdog problem
I'm using the Labview FRC example project (update2.0), and after deploying to CRIO, the Tele mode is fine but the during Autonomous mode, the driver station panel shows "Watch dog not fed". Anyone had got this problem before?
Currently Gyro and camera is not conectted to the system yet - but I assume that should not cause the watchdog problem?
Problem with System Watchdog JSonntag NI LabVIEW 14 20-02-2010 11:31
Autonomous Watchdog Issues Rafael Vasquez Programming 3 28-01-2010 08:01
code example to set 4x encoder decoding mode mode fdelagarza C/C++ 1 02-02-2009 17:14
Simple Autonomous Mode Example deltacoder1020 Programming 5 08-03-2004 20:22
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
