example project Autonomous mode Watchdog problem
I'm using the Labview FRC example project (update2.0), and after deploying to CRIO, the Tele mode is fine but the during Autonomous mode, the driver station panel shows "Watch dog not fed". Anyone had got this problem before?
Currently Gyro and camera is not conectted to the system yet - but I assume that should not cause the watchdog problem? |
| Problem with System Watchdog | JSonntag | NI LabVIEW | 14 | 20-02-2010 11:31 |
| Autonomous Watchdog Issues | Rafael Vasquez | Programming | 3 | 28-01-2010 08:01 |
| code example to set 4x encoder decoding mode mode | fdelagarza | C/C++ | 1 | 02-02-2009 17:14 |
| Simple Autonomous Mode Example | deltacoder1020 | Programming | 5 | 08-03-2004 20:22 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
