Go to Post My favorite question of all time asked by "outsiders": How much does/did that thing cost? How can you put a price on the hard-work and dedication it took to build these machines? - KyleGilbert45 [more]
Unread 08-02-2010, 16:49
aceshigh2729 aceshigh2729 is offline
FRC #2729
aceshigh2729 is an unknown quantity at this point
Attaching a gear to a SIM motor
how do you do it w/o opening up the motor.
Unread 08-02-2010, 16:54
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Attaching a gear to a SIM motor
The output is keyed for a 2mm x 2mm machine key.
You can purchase gears and hubs that are broached for the CIM output shaft at www.andymark.biz or broach another item yourself.
Do not take the motor apart as that is an illegal modification and you will be unable to compete with that motor.
--Madison--
...down at the Ozdust!
Unread 08-02-2010, 17:17
FRC #2729
we need to know how to attach gears w/o using a gearbox
Unread 08-02-2010, 17:25
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
http://andymark.biz/am-0320.html
This hub fits directly to the cim. Im not sure if it comes with a key or not, so it might have to be ordered separately.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 08-02-2010, 17:28
CraigHickman
Posts: n/a
Could you cite a rule for this? I had interpreted past rulings as the motor windings cannot be modified, nor the magnets, but the casing could be machined and modified for mounting reasons (and machining the case would require removing the front plate).
Unread 08-02-2010, 17:32
<R54> So that the maximum power level of every ROBOT is the same, motors and servos used on the ROBOT shall not be modified in any way, except as follows:
A. The mounting brackets and/or output shaft/interface of the motors may be modified to facilitate the physical connection of the motor to the ROBOT and actuated part.
B. The gearboxes for the Fisher-Price motors are not considered “integral” and may be separated from the motors.
C. The electrical input leads on the motors may be trimmed to length as necessary.
The intent is to allow teams to modify mounting tabs and the like, not to gain a weight reduction by potentially compromising the structural integrity of any motor. The integral mechanical and electrical system of the motor is not to be modified. Note that FIRST will not provide replacements for modified parts.
The only questions are, is machining the case a legal modification, and if it is, are you allowed to open the motor to do it? If it's to facilitate mounting, yes. Otherwise, no. As for the second part, it's anybody's guess.
Unread 08-02-2010, 17:35
Madison's Avatar
FRC #0488 (Xbot)
A. The mounting brackets and/or output shaft/interface of the motors may be modified to facilitate the physical connection of the motor to the ROBOT and actuated part. , except as follows:
© FIRST 2010 FIRST Robotics Competition Manual, Section 8 – The Robot, Rev G Page 25 of 33
Where the CIM motor is concerned, I would not consider its casing to be a "mounting bracket" or "output shaft/interface."
The Nippon-Denso motors contain mounting brackets that are obviously not integral to the mechanical operation of the motor. The CIM is not as clear cut.
--Madison--
Unread 08-02-2010, 23:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
What if I don't modify anything when I have it apart? I only press on a gear? (such as a Dewalt pinion)
Unread 09-02-2010, 02:03
Yeah, there's the rub. The question, which somebody who actually has a Q&A account should ask, is: "In the process of performing a legal modification to a CIM motor, it may become necessary to take it apart and put it back together. Is it legal to do so, provided that nothing else is done besides removing a piece, legally modifying it (e.g., adding a mounting hole), and putting it back in?"
Attaching a small gear to Denso window motor? grosh Motors 3 07-02-2010 14:49
Attaching Denso motor adapter to the motor? Billfred Motors 3 19-02-2007 20:07
Attaching Mini-Bike motor to stock banebot gearboxes! brennerator Technical Discussion 2 29-01-2007 17:03
Drill motor in a Dual Motor gear box MBosompra Technical Discussion 3 16-01-2004 21:37
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
