Go to Post All the "official game hint" is is an "official red herring" - Cory [more]
Unread 08-02-2010, 18:56
darkorbit's Avatar
darkorbit darkorbit is offline
Electrical?!
AKA: Jin Lem
FRC #0069 (HYPER ROBOTICS)
darkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to all
crio dashboard GPIO output
How do you get the dashboard to should active GPIO output?
2007 BOSTON REGIONAL WINNERS (NU-HYPER-FORCE)
2008 Florida Regional 2nd Place
Unread 08-02-2010, 19:00
PapaRobocat PapaRobocat is offline
FRC #2161
PapaRobocat is an unknown quantity at this point
Re: crio dashboard GPIO output
We are having trouble getting our robot function at all. The speed controlers wont work and the signal light is going out when the robot is enabled. in short all the signal lights on the robot (jaguars,spikes, and sidecar) and the air compresser are going off at the same time. the driver station is saying watchdog not fed at the same time as the lights go out. I am out of ideas as to what the problem is.
Unread 08-02-2010, 19:31
I got Mr. Rogers' email.
Are you sure you're using a fully charged battery?
Unread 08-02-2010, 20:22
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
TPNigl is an unknown quantity at this point
Yes, we were using a fully charged battery
2011 Pit Crew:
2011 CT Xerox Creativity Award
HYPER Alumni
Unread 08-02-2010, 20:33
Sorry, that was addressed to that 2nd off-topic post.
To get the GPIO to show on your Dashboard you'll need to add the GPIO values into the Dashboard feed in your code on the cRIO.
What language are you using?
Unread 08-02-2010, 21:26
Whoops, sorry about that. We're using java. How exactly do you add the GPIO values into the Dashboard feed?
2011 Pit Crew:
HYPER Alumni
Unread 08-02-2010, 21:55
Check the Java examples for use of the Dashboard classes, such as, DashboardDataSender.
Unread 09-02-2010, 06:23
darkorbit's Avatar
Electrical?!
AKA: Jin Lem
Thanks for your time. I found how to do it in the manual xD last night.
Unread 09-02-2010, 15:29
Yea, thank you very much. We used the default code you suggested and it worked. Thanks!
2011 Pit Crew:
HYPER Alumni
Solenoid Output in Dashboard rhf323 Programming 6 03-02-2010 09:30
cRIO output problem alex42 FRC Control System 1 27-01-2010 22:28
Using a GPIO pin for both input and output. Shinigami2057 C/C++ 6 24-02-2009 20:04
Dashboard Analog Meters and GPIO? Geek_Girl Programming 1 17-12-2008 09:50
Dashboard Output Question jnossen Technical Discussion 5 02-02-2002 19:52
