Go to Post CD would not be what it is without Brandon - Richard Wallace [more]
Unread 08-02-2010, 19:02
PapaRobocat PapaRobocat is offline
FRC #2161
PapaRobocat is an unknown quantity at this point
at Whits end
The speed controlers wont work and the signal light is going out when the robot is enabled. in short all the signal lights on the robot (jaguars,spikes, and sidecar) and the air compresser are going off at the same time. the driver station is saying watchdog not fed at the same time as the lights go out. I am out of ideas as to what the problem is.
Unread 08-02-2010, 19:05
Captain banana's Avatar
Captain banana Captain banana is offline
Ruler of man
AKA: Marcus
FRC #1510 (The Wildcats)
Captain banana will become famous soon enoughCaptain banana will become famous soon enough
Re: at Whits end
I'm going to guess that someway, somehow, you contracted a virus by a person who has a terrible sense of humor. you could run some standard anti-virus software, or just get attempt to get a new drivers station. Try it, it will probably help.
Unread 08-02-2010, 19:14
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Re: at Whits end
It appears as though you weren't the only one. I don't think this fixes your problem, just verifies there was a problem.
http://forums.usfirst.org/showthread.php?p=37127
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 08-02-2010, 19:24
Re: at Whits end
It sounds like your battery is not fully charged.
Does an orange "status" light on the cRIO come on at the same time?
A couple of LEDs below where the green "power" LED is.
Unread 08-02-2010, 23:02
Re: at Whits end
If everything is going dark, including the Jaguar status LEDs, it sounds like you have a power issue. If a discharged battery isn't the problem, look for shorted wiring on the output of your speed controllers and Spikes.
I'm a little worried about your description of when the compressor turns off. It sounds like you said it quits when the robot is enabled, which implies that it runs while the robot is disabled. I hope I misunderstood that part. If the compressor indeed runs before you enable the robot, it has been seriously miswired.
Autonomous end game bear24rw General Forum 33 25-04-2007 16:21
End Game Size almsfan21 General Forum 2 07-02-2007 19:24
Build Coming to an end.. Tom Bottiglieri General Forum 1 15-02-2004 13:06
End caps? Levaman Kit & Additional Hardware 7 09-02-2004 02:41
End of match tethering DirtyBird213 Rules/Strategy 2 15-01-2004 20:29
