Go to Post Please drill responsibly! - IKE [more]
Unread 08-02-2010, 20:25
AdamHeard's Avatar
Lead Mentor
Re: pic: Team 8 Teaser #2
I find it interesting that you are engaging the ratchet with a dog.
Assuming this is for a stored energy system, what was your basis for this decision?
Unread 08-02-2010, 22:55
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I'll venture a guess:
The dog is to engage and disengage a motor, but the ratchet takes the loads so that the motor isn't stalling holding the ratchet in place. The motor must disengage when the system is fired to reduce the friction when the ratchet (and whatever it's holding) spins.
Unread 09-02-2010, 03:16
Rasmus's Avatar
Rasmus Rasmus is offline
FRC #0008
Rasmus is an unknown quantity at this point
we have 2 reasons why we machined the dog gear in the ratchet. first off, the above guess is correct, and second of all. we did this because we could
-Team 8
Unread 12-02-2010, 21:23
Alan Ing Alan Ing is offline
None #0368 (Kika Mana)
Alan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond repute
Hi,
How do you like the Tormach? How old is it? We have one too. Nice little machine, made 24 sprockets for our machine this year and still counting.
Regarding your coolant. How has the coolant held up. Do you find that it eventually lifts the paint of the coolant tray? So far we have tried two different coolants and they both cause the paint of the coolant tray to lift.
What CAM program are you using? We are using mastercam and have been pretty happy with it.
Alan
Mentor for Team 368
Unread 17-02-2010, 03:06
Rasmus's Avatar
FRC #0008
Originally Posted by Alan Ing View Post
Hi,
Alan
Mentor for Team 368
I have been using the Tormach for i think 50 plus hours and about 30 plus cnc jobs, and i love it! I do not know how old our machine is because we got it generously donated to us by Tormach, we got it used, but in a fantastic condition(many thanks to Tormach).
The coolant we use work great, tho we usually dont use flood coolant for aluminum which is prime material we work with and we just use compressed air for that. We have not had any problems with the paint chipping off, What kind of coolant are you guys using? the only little problem we have had with the coolant is that it does evaporate with time so you have to make sure the container is full when starting a new job, otherwise you might run out when you are half way thought a cut(trust me this causes a bit of panic)
I have been CAMing everything with MastercamX3 which does work, even though it was really hard to figure out (self taught). and the fact that ctrl S is not actually a save hot key, did cause some swearing
-Rasmus Rossen
-Build Captain, Team 8
pic: Team 40 Teaser Greg Needel Extra Discussion 5 28-01-2010 23:42
pic: Team 25 Teaser nparikh Extra Discussion 11 18-02-2007 20:33
pic: team 73 teaser Greg Needel Robot Showcase 7 10-02-2005 00:32
pic: Team 45 teaser Alan Anderson Extra Discussion 11 31-01-2005 12:30
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
