Go to Post The only thing happy about ship day is the promise of sleep coming soon... - StephLee [more]
Unread 23-01-2010, 22:01
NerdGuy's Avatar
NerdGuy NerdGuy is offline
FRC #2974
NerdGuy is an unknown quantity at this point
Wiring Encoders?
Hey so i am a bit confused as to where the optical encoders go on the digital sidecar
Can they plug into the Digital I/O slots?
Also what color wire correspond to 5V,GRND, and sig1,sig2, from encoders (assuming standard kit from first)
"Life would be so much easier if we only had the source code."
Unread 23-01-2010, 22:11
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Wiring Encoders?
They go to the Digital IO section.
You will need some spare PWM cables to connect the encoders, two per encoder. There are four wires in the encoder - Plug the cable into the encoder and read the labels on the cover for what wire goes to what. There should be an +5v, A, B, and Gnd. Cut the female end off of each PWM cable, leaving enough cable to run from your DSC to wherever your encoder is. You do not need the male end. Wire the red wire from one of the two cables to the +5 wire, the black one to the GND wire, and the white from one to the A wire. The other one will only need the white wire, and that will connect to the B wire. It does not matter where you plug the cable into the DSC, as long as they are in the Digital IO section. Usually you would plug them in to IO pins next to each other.
If you need help with the software, ask.
Kettering Motorsports
Unread 23-01-2010, 23:02
NerdGuy's Avatar
FRC #2974
OK thanks we will try that tomorrow.
Unread 28-01-2010, 13:34
bobvader505 bobvader505 is offline
FRC #0343
bobvader505 is an unknown quantity at this point
Thanks from team 434 as well!
Unread 30-01-2010, 19:27
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
which wires are channel A and channel B???
Unread 30-01-2010, 20:33
apalrd's Avatar
More Torque!
VRC #3333
As in which port goes to what wire?
It dosen't matter, if you get them backwards the controller will think the robot is going in the other direction. If the robot thinks its going backwards then swap the A and B wires.
What color wire?
Plug the cable into the encoder and read which wire is A and B. It should be labeled.
Unread 30-01-2010, 20:43
DonRotolo's Avatar
Back to humble
FRC #0832
Perhaps you should look here.
I got that from the FRC Manual. Did you look there?
Unread 08-02-2010, 17:15
jaster67 jaster67 is offline
Jose Sanchez
FTC #2978 (Cavaliers)
jaster67 is an unknown quantity at this point
Umm, could you please post a picture of an encoder wired properly? It would be a great help.
I will give you a million dollars if you don't read this sig.
Unread 08-02-2010, 21:58
apalrd's Avatar
More Torque!
VRC #3333
I'm not at the BotCave right now, so I'll use a picture from AndyMark's site. You plug the encoder cable into the encoder board, make sure it is in. Then, you place the cover on top of it so you can see how the labels line up. You take two PWM cables, and cut the male end off of them. You strip all three wires of one and only the white or yellow wire from the other. You connect the red wire from the first cable, to the cable that matches with the "+5v" on the encoder. Solder it and wrap the connection in electrical tape or heat tubing. Then, connect the black wire from the first cable to the wire that matches the "gnd" on the encoder. Then, you connect the white or yellow wire from the first cable to the "A" wire on the encoder. You connect the white or yellow wire from the second cable to the "B" wire on the encoder. You plug the two PWM cables into the Digital SideCar in the Digital IO section, not the PWM section. The black wire goes to the outside. If the software sees your robot going backwards, you need to switch the two PWM cables on the Digital Sidecar so the A is where the B was and the B is where the A was, or set the gain negative.
Encoders..... manderson5192 Programming 4 07-02-2008 10:10
Wiring Gyros and Encoders? SuspectZero Electrical 3 03-02-2008 15:30
Encoders Ctx32 Programming 8 13-05-2006 23:54
3 Encoders stephenthe1 Programming 5 17-11-2005 19:21
