Go to Post The mecanum is like the dress shoe, the treaded wheel is like the athletic shoe. - Chris Fultz [more]
Unread 08-02-2010, 22:02
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
materials rules
rookie team would like confirmation: Would expanded metal being used in the bottom of the frame be seen as a safety problem? It has sharp edges, but they have all been covered by caution tape so that no edges are exposed. It would make feel better if someone said this will pass the safety inspectors.
Unread 08-02-2010, 22:47
Electrical Engineer
Rookie Year: 1995
Re: materials rules
I have seen expanded metal safely used before.
I can't comment on your covering of sharp edges. My gut feeling is that tape may be too thin of a guard against getting cut but I'd have to see it.
Mike Betts
As easy as 355/113...
Unread 08-02-2010, 22:51
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: materials rules
If it's just caution tape (like the non-sticky stuff?), it won't fly too well with the inspectors, but duct tape works quite well. We've actually had a few inspectors recommend it for sharp spots that we couldn't get to with a file. However, repeated pressure/force on the tape against the sharp metal will require you to use several layers, depending on the quality of the tape.
However, all inspectors and events are different. I'd suggest filing it down, if you can.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 08-02-2010, 22:55
FRC #3179
Re: materials rules
I should have specified,the tape is a type of strong tape that I use in the computer lab for covering wires on the floor and such when needed. We happen to be out of duct tape and the kids thought that would look cool anyway to have the caution striped tape. Thanks for your thoughts.
Unread 08-02-2010, 23:04
AKA: Kara Bakowski
Re: materials rules
Like this stuff, maybe? It works pretty well, but covering corners is tricky.
Kara Bakowski
WMWBS '10 '11
Unread 08-02-2010, 23:10
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: materials rules
I'm with Mike on this one - I've seen it used and have had no problem passing it before, but it really depends on the particular application. Without being able to actually run my hands over the edges of it, it's really impossible to say. There is nothing in the rules specifically that prohibits the expanded metal, but be prepared for the possibility of being asked to add more tape. My general criteria when asked to make those sorts of decisions is "would I rub my face on it?"
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 08-02-2010, 23:45
FRC #3179
Re: materials rules
Actually, I would say it is smooth as a baby's bottom http://www.chiefdelphi.com/forums/im...lies/yikes.gif
Unread 09-02-2010, 01:52
Re: materials rules
You mean like gaffer's tape? Should be OK, but you'll want to replace/repair it every few rounds or so.
Also note that you should have somebody go after the edges with a file to smooth them out before tape is applied--the sharp parts may be more likely to go through the tape.
My team used expanded aluminum in 2007 as the bottom section of a ramp for other robots. One event later, after both sides had ruts, we switched that to corrugated plastic for less permanent deformation.
Materials fireball3004 3D Animation and Competition 6 21-02-2008 02:10
Composite materials allowed in 2007 Rules? cbale2000 Technical Discussion 5 24-01-2007 23:16
Regional-specific rules, etc., and do the referees read the rules? Kit Gerhart Rules/Strategy 53 18-04-2005 08:51
Dilemma - Letter of the rules v. spirit of the rules Natchez General Forum 27 03-04-2003 15:37
Materials archiver 2000 1 24-06-2002 00:20
