Go to Post Only one full day of brainstorming on the hint? Boy are they behind... This thread's been busy for a week! - EricH [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 06-02-2010, 17:22
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Uncaught exception
[cRIO] Uncaught exception in Thread.run():
[cRIO]     on thread edu.wpi.first.wpilibj.templates.RobotTemplate - main
[cRIO] java.lang.IllegalArgumentException: MIDlet class specified, edu.wpi.first.wpilibj.templates.RobotTemplate, was not found
[cRIO]     at java.lang.Throwable.<init>(88)
[cRIO]     at java.lang.Throwable.<init>(102)
[cRIO]     at java.lang.Exception.<init>(53)
[cRIO]     at java.lang.RuntimeException.<init>(58)
[cRIO]     at java.lang.IllegalArgumentException.<init>(54)
[cRIO]     at com.sun.squawk.imp.MIDletMainWrapper.main(94)
[cRIO]     in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO]     at com.sun.squawk.Isolate.run(1554)
[cRIO]     at java.lang.Thread.run(231)
[cRIO]     in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO]     in static method #3 of com.sun.squawk.VM(bci=6)
We don't really know how this happened, but it broke sometime around when we tried to change the package name of the default code. Is there a way to get around this? How would we modify the midlet configurations in the Manifest file?
Unread 06-02-2010, 18:54
ygd ygd is offline
FRC #3341 (Manhattan Project)
ygd is an unknown quantity at this point
Re: Uncaught exception
In Netbeans go to Tools -> Plugins and click the Settings tab.
Select FRC Java or whatever you named it and make sure the update site is:
If it isn't, uninstall the FRC Plugins and change the update site and reinstall.
Unread 06-02-2010, 19:15
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
You'll see this behavior if you change your package name after creating your project. Edit the file in ./resources/META-INF/MANIFEST.MF so that it uses your package and class name.
The default file will look something like this:
MIDlet-Name: RobotTemplate
MIDlet-Version: 1.0.0
MIDlet-Vendor: FIRST
MIDlet-1: RobotTemplate, , edu.wpi.first.wpilibj.templates.RobotTemplate
MicroEdition-Profile: IMP-1.0
MicroEdition-Configuration: CLDC-1.1
Replace 'RobotTemplate' with the name of your robot class, and 'edu.wpi.first.wpilibj.templates' with your package name.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 06-02-2010, 19:27
phencer42's Avatar
phencer42 phencer42 is offline
FRC #1517 (P4)
phencer42 is on a distinguished road
Send a message via MSN to phencer42
Thanks MattD
We've been confused for a bit and were starting to get worried. We tried what you said and it worked perfectly. Team 1517 thanks you.
Study=No Fail
No Study=Fail
No Study+Study=No Fail+Fail
(No+1)Study=(No+1)Fail
Study=Fail
Unread 08-02-2010, 22:13
Programming
Looks like it worked for us too. Thanks for your time and help!
Unread 08-02-2010, 22:40
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
I gave up on changing our default code name since week 1, so this is very helpful. Thanks a lot, Matt!
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
EnhancedIO Exception Error coo Java 2 30-01-2010 11:09
Wait Exception? NinJA999 Java 3 15-01-2010 14:13
Exception in Timer.cpp Phazonmutant C/C++ 2 17-02-2009 09:27
Target Exception - Exception in Kernal Task Thxe C/C++ 3 10-02-2009 07:24
Joystick Exception? Blair Frank Control System 3 09-02-2007 22:41
