Go to Post We may be changing cheese heads for cheesy poofs, but in the imortal words of Gen. MacArthur "we shall return" (team # 2437) - cdebo [more]
View Poll Results: What are planning on doing? (select all that apply)
Hanging from the tower 94 66.67%
Hanging from an alliances' robot hanging on the tower 29 20.57%
Allowing alliance to hang from us 33 23.40%
Sitting on the tower 14 9.93%
Nothing, just score goals 42 29.79%
Multiple Choice Poll. Voters: 141. You may not vote on this poll
Old 08-02-2010, 22:55
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
Re: Who is hanging and how?
Something along the lines of this
Old 09-02-2010, 00:11
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
Carbon fiber grappling hook + carbon fiber telescoping arm.
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Old 09-02-2010, 01:05
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Lifting is best solved by a TENSION solution. Ramps are compression based.
Compression is high mass and produces TORQUE.
Tension is self aligning and LOW MASS.
Think cables and synthetic fiber lines.
-Dick Ledford 3135 Robbotic Colonels
Old 09-02-2010, 01:47
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Originally Posted by IndySam View Post
but how do you fit a 30 degree ramp in a 84 in circle?
A combination of pneumatics and a ramp deploying mechanism.
Technically 27.xx degrees.
Old 09-02-2010, 02:14
AKA: Dick Ledford
Does your bot traverse the tunnel? Why the telescoping scheme, when getting from the 60" max. vert. bot size limit to the 84" bar requires only a 24"+hook size swing arm. Seems harder to do telescoping?
-Dick Ledford
Old 09-02-2010, 02:22
No we only cross the bump. We want to keep the arm low and close to the robot to help keep a low CG.
Telescoping should be easy how we do it. Connecting the bottom of the upper(inner) tube to the top of the bottom(outer) tube with surgical tubing. We'll use a worm transmission to hold the upper tube down inside the bottom tube against the tension, unwind the worm to release tension, allowing the arm to spring up, then after hooking, re-wind the worm to lift our robot up.
Old 09-02-2010, 08:59
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
To lift a robot onto your robot that is on the platform?
Old 09-02-2010, 15:57
Salbert's Avatar
Salbert Salbert is offline
AKA: Sal
Salbert is a name known to allSalbert is a name known to allSalbert is a name known to allSalbert is a name known to allSalbert is a name known to allSalbert is a name known to all
Send a message via AIM to Salbert
Bruceb,
I agree on the hanging by yourself part.
Its only 2 points.
I suspect that the superior robot is one that can hang and "lift" or "carry" another robot for the 5 pointers.
The lack of rampbots discussed in CD is surprising to me for possible 4 pointers. If robots are being built to climb 45 degree angles, isnt it very possible to climb a 30 degree one?
How are rampbots 4 pointers?
Old 09-02-2010, 19:53
GaryVoshol's Avatar
Cogito ergo arbitro
If the other two bots climb your rampbot to become ELEVATED, they get 2 points each.
(since 2004)
Old 09-02-2010, 20:27
Nickel5 Nickel5 is offline
FRC #2472
Nickel5 is an unknown quantity at this point
Bruceb,
Its only 2 points.
Good luck achieving any rampbot. From the near part of the tower (from the driver's station) to the far part, the distance is less than the length of the robot. While the wheels won't be on the edge of the bot, it is still a very small room for the robot to fit on, and any error could be catostrophic. Plus, if one robot getting 2 points is questionable, then 2 robots getting 2 points should be out of the question. It is almost impossilbe for 2 robots to fit on the platform side by side, and in any eleimination round at least 1 of your alliance partners should be able to hang by themselves.
The only way I could see a ramp bot being worthwhile would be if the ramp bot could hang from the elevated bot, but this would most likely just result from the elevated bot being pulled down and landing on the rampbot.
My team is going with a telescoping rod with a grappling hook on the end. The hook detaches and the bot is winched up. Incase that somehow fails, we have a side hanger being made too as a back-up.
Old 09-02-2010, 20:30
Chris is me's Avatar
AKA: Pinecone
Never say never. As long as the whole robot is above the plane of the platform it is ELEVATED. The ramp's "top" could be longer than the platform in theory.
Old 09-02-2010, 20:41
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
And the robot is touching the tower. It may be tricky(but not impossible) to get the second robot you are trying to elevate in contact with the tower if the first robot doesn't quite fit and has to hang off.
Old 09-02-2010, 23:00
bobl bobl is offline
FRC #0058 (The Riot Crew)
bobl will become famous soon enough
Team 58 - The Riot Crew will be hanging. In fact we tested our robot tonight. Video can be seen on youtube
http://www.youtube.com/watch?v=9TToKIpXpVI
We hope to make it a little faster but it works.
Old 10-02-2010, 00:12
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Tested the hooks the hooks tonight, nice and light weight...
ID:	8597  Click image for larger version
Old 10-02-2010, 00:56
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
If our team ever gets off our little #25 chain tangent, we'll finally get back to making our lifting arm work with 3840-pound breaking strength Dyneema. We snapped our 1050-pound Spectra A spearfishing line, so our mentor has typecast the material as being weak, and he's trying to get it to work with #25 chain. But once we get back onto the Dyneema (since the chain failed tonight, even faster than the Spectra), we'll be set up to support two robots and ourselves.
Hanging robots and <G31> ssa3512 Rules/Strategy 20 13-01-2010 17:22
2007 Indy 500 - Who is going and who will be watching? Cynette Chit-Chat 20 27-05-2007 09:30
YMTC: Bluabot and Redabot hanging? Natchez You Make The Call 15 23-03-2004 01:42
pic: Team 340 Hanging and Uncapping CD47-Bot Robot Showcase 1 23-02-2004 11:02
Starting position and hanging clarification Don Wright Rules/Strategy 2 10-01-2004 14:21
