Go to Post ... you know you are a nerd when you want safety glasses for your birthday! :P - Ashley Christine [more]
Unread 08-02-2010, 22:41
kngscrpn24 kngscrpn24 is offline
Student VP and Programmer
AKA: Ed C
FRC #2064 (Panther Project Robotics)
kngscrpn24 is an unknown quantity at this point
Exclamation HELP I'm Losing it! aka Labview deploy vs. run
Okay everyone,
So today I had a bad day and I really need some answers, so instead of my customary comfort of bedtime Game Manual reading, I have resorted to bedtime CD Posting.
Anyway, today team 2064 finally started to program (yes, I know it's a bit late). Anyway, Classmate was set up correctly. cRio was imaged. In short everything was connected as it should have been. So there was no hardware issue.
We used sample software, so there should have been no software issue.
My question pertains to the two accounts on the Classmate. My teamates and I were used to always clicking "run" last year, as deploying took ages. When we attempted clicking run while in the developer account, everything would be loaded properly onto the cRio, but there seemed to be a disconnect between the driver station and the robot (which were hard-wired)- specifically the stop button. The robot was in a consistent disabled state.
But upon deploying in the developer account, then logging off and going into the driver account, the robot would function perfectly.
So yes, we got our program to work, but frankly, all this switching seems a ridiculous inconvenience. I mean we could use one laptop to program, and always use the classmate for the ds, but even then we would still need to deploy. So I have come to the conclusion that there must be a quicker way to test our programs. I just don't know what it is!
I am well aware that somewhere in the depths of the programming forum there must be an answer to this question; in fact it seems to be that type of question that close to everyone asks. Yet right now I need to do a bazillion things and I know this is a really lame excuse and I know that everyone hates repeated answers, so....
If anyone could write a really quick response or point me to the right thread I'd be a very happy programmer (an oxymoron, indeed!).
And yes I know I ramble!
-Ed C.
VP & Senior Programmer
Team 2064
2007 Rookie Inspiration Award
Unread 08-02-2010, 23:02
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Talking Re: HELP I'm Losing it! aka Labview deploy vs. run
ok go to the programs and the driver station that is pulled up in the drivers account will be there so you can "run" your code on the developer as well as operate it by opening this program
Unread 08-02-2010, 23:07
AKA: Ed C
I'm confused (which is easy to do). Which account can access which account? Thanks for a quick reply!
-Ed C.
Team 2064
Unread 08-02-2010, 23:09
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You have to have the Driver Station open to enable the robot.
It sounds like what you want to do is log onto the Developer account (make sure the Driver Station is not open on the Driver account!) and open Labview and Run your code. Then open the Driver Station from the Start Menu and enable the robot.
Unread 08-02-2010, 23:15
AKA: Jon
ok their are two ways to get the code running on the robot
1.Build then run as startup (which is long and permanent meaning that you can reboot and it will still be there)
2.Run off of robot main(Faster but not permanent) and open the driver-station located in all programs from the start menu
AKA: Ed C
You can open the driver station from the start menu? Does it run just like any other windows application? Or do I need to switch users?
-Ed C.
Team 2064
Unread 08-02-2010, 23:16
AKA: Jon
it runs just like a regular application on windows no need to switch users open it in developer and you're set
Unread 08-02-2010, 23:19
AKA: Ed C
Is driver station located under the Labview subfolder?
-Ed C.
Team 2064
Unread 08-02-2010, 23:21
AKA: Ed C
Thanks all!
-Ed C.
Team 2064
Unread 10-02-2010, 19:24
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Here's what we do to test.
1. Open Developer
2.Make sure Robot is on and connected (wired or wireless)
3. Open your program
4. Open robot main
5. Click Run arrow
6. Wait.
7. Open Driver Station (we made a shortcut onto the desktop can be done by opening start menu finding the program holding down right click and dragging on to the desktop)
8. 3 green lights Enable
9. Disable
10. Stop Robot Main
11. Edit code
12. Start from step 4 and repeat
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 10-02-2010, 19:40
AKA: Ed C
Lightbulb Re: HELP I'm Losing it! aka Labview deploy vs. run
Originally Posted by j.cole View Post
11. Edit code
We do these two steps a lot ! Thanks- you left out the pulling-out-your-hair-when-you-don't-know-what's-wrong part, though . That step is critical!
-Ed C.
Team 2064
Unread 20-02-2011, 23:22
buck buck is offline
Junior Member
FRC #7777
Team Role: Tactician
Rookie Year: 1900
buck is an unknown quantity at this point
How would I go about ruining it as a startup?
Unread 20-02-2011, 23:41
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
While you're in the project explorer (the small window that shows all of your vi s), click the + next to build specifications, then right click on FRC boot-up Development and click build. When it's done building, right click on it again and select run as startup. (You might have to reboot the robot here, I forget.) Then open up the driver account, and you should get the robot code light green a few seconds after communications.
Labview programming help - Deploy mode not working ferc Programming 3 20-10-2009 18:32
Robot will Run but Not deploy 663.keith NI LabVIEW 8 14-02-2009 17:52
Run works but build&deploy doesn't program1 NI LabVIEW 3 03-02-2009 22:32
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
Help to Deploy a Program in Labview. Delian NI LabVIEW 7 10-12-2008 21:13
