Go to Post My suggestion is to first focus in on your drive base. Get it running, and drive it into the ground and see what breaks. Then fix it. Rinse wash and repeat. - Andy A. [more]
Unread 02-09-2010, 07:14 AM
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Re: NetBeans Debugging
Do you have the latest updates?
Are all IP addresses correct?
Is the firewall on the development PC turned off?
Is WIFI connection on the development PC turned off? I have seen this be a problem occassionaly.
Are you using a wired connection between cRIO, drivers station, and development pc? Wired eliminates any radio configuration issues.
Are there any error messages on the output display?
What example program are you using? Use a simple unmodified sample to make sure that you understand how the development environment works.
Are the enable/disable autonomous/operator control settings on the drivers station appropriate for the section of code you want to debug?
Chuck Harris
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Debugging FRC4ME Java 1 01-21-2010 12:16 AM
Netbeans help please darkorbit Java 1 01-18-2010 09:36 PM
Program C++ in NetBeans? camper365 Programming 7 01-17-2010 10:12 PM
Help with NetBeans frcchile Java 4 01-13-2010 09:51 PM
debugging help ringo115 Programming 1 02-15-2009 04:22 PM
