#15
Re: How to hook up Nason pressure switch
Electrically it makes no difference.
If you want to be a stickler for convention, however, the "C" stands for Common and ought to be wired to ground. The "NC" or Normally Closed contact ought to be wired to the signal input pin. |
| nason pressure switch wire | holty531 | Pneumatics | 3 | 31-01-2008 22:18 |
| Nason Pressure Switch? | DPPT1717 | Pneumatics | 10 | 09-01-2007 22:31 |
| No value in digital ins using NASON pressure switch. | Ari Allyn-Feuer | Programming | 1 | 18-02-2006 01:18 |
| Urgent need for Nason pressure switch!! PLEASE HELP! | haverfordfords | Pneumatics | 12 | 18-02-2005 02:04 |
| Nason pressure switches | JP_1163 | Pneumatics | 11 | 03-03-2003 23:03 |
