Go to Post Being a mentor only requires an open mind and fifty thousand times more responsibility. - Amanda Morrison [more]
Unread 27-01-2010, 19:01
tutkows1's Avatar
tutkows1 tutkows1 is offline
FRC #2077
tutkows1 is an unknown quantity at this point
Re: 2010 FRC Camera Live Feed Lag
We are haveing the same problem also, are your saying a quick fix for this problem is to run the driverstation under the developer account?
Unread 31-01-2010, 14:55
dmlawrence dmlawrence is offline
MIT '14
FRC #1751 (Warriors)
dmlawrence is an unknown quantity at this point
Same problem here as well
Unread 31-01-2010, 17:26
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
I found the problem to be the graphs on the right side of the dashboard were causing a huge delay. I removed them and we now get near instant video (minus expected network latency). Our fixed dashboard is here http://www.chiefdelphi.com/forums/sh...ad.php?t=81378
Unread 31-01-2010, 17:46
AKA: Ian Thompson
/\ is our solution. The graphs on the right side of the Dashboard were lagging the image considerably so we took them out of the Dashboard and the image is very fast now (only the expected network latency). The fixed Dashboard is attached
Unread 08-02-2010, 15:31
Damaku250's Avatar
Damaku250 Damaku250 is offline
Electromechaneumatics guy
AKA: Craig Hoo
FRC #3161 (H.T. Tronic Titans)
Team Role: Electrical
Damaku250 is an unknown quantity at this point
What do you guys mean by "logging into the camera?" Is it the Axis Camera setup? Or are we talking about logging in by navigating to its IP address (and what would that be if this is the case)?
-Rookie All Star Award [WAT Regional 2010]
Electrical/Control systems, Mechanical and Pneumatics teams, Human player
Unread 08-02-2010, 22:18
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
We're talking about connecting the camera to the computer via crossover cable, setting your computer's IP & subnet to 192.168.0.99 & 255.255.255.0, and typing http://192.168.0.90 into your browser. 192.168.0.90 is the camera's default IP address.
Unread 09-02-2010, 09:44
goodsky's Avatar
goodsky goodsky is offline
Programming Mentor
AKA: Skyler
FRC #1902 (Exploding Bacon)
goodsky has a spectacular aura aboutgoodsky has a spectacular aura aboutgoodsky has a spectacular aura about
I want to check to make sure that anybody having this issue has seen the latest update (this is for C/C++) that in the description says, "the camera code now is much more efficient with less copies and image buffer allocations in the library.The PC Video server (images back to the dashboard) are much faster now – it should in most cases run at the full camera rate. For image sizes of 320x240 the total lag should be around 0.5 seconds. Smaller images are lower."
If you are using windriver this might help out. I haven't seen an update like this for Labview or Java yet, although I haven't looked as hard.
Get the Updates from here: http://first.wpi.edu/FRC/frccupdates.html
OINK OINK BOOM!!!
Unread 10-02-2010, 23:05
cheesepuffgd's Avatar
cheesepuffgd cheesepuffgd is offline
imperial majesty of all programming
FRC #0955 (raiderbot)
cheesepuffgd is an unknown quantity at this point
Question Re: 2010 FRC Camera Live Feed Lag
I have had that problem with the camera feed. We are using the lowest resolution, we are running it in the developer account with nothing else open. it is programmed in C++. Is there anything I can do about this?
Unread 11-02-2010, 02:33
Are you using the new update for C++? The second issue that can cause lag is that the driver station is bogged down. You can check with the task manager.
Greg McKaskle
Yet Another Axis Camera Live Feed Issue z2daj FRC Control System 2 24-01-2010 13:47
Live Feed with Axis Camera CHSboy Programming 6 24-03-2009 14:43
2009 - Live camera feed to drivers during a match? Travis Hoffman Rules/Strategy 23 21-01-2009 17:43
Getting Live Feed from Axis Camera in Windriver Inoperational C/C++ 8 15-01-2009 01:21
live feed? miop Programming 1 02-02-2008 21:24
