Go to Post There's a fine line between idolizing someone and stalking! - Jay H 237 [more]
Unread 09-02-2010, 09:57
l0jec l0jec is offline
l0jec has a spectacular aura aboutl0jec has a spectacular aura about
Re: [FTC]: Robot problems with motor movment
You issue is likely with floating the motors in ROBOTC:
    else
      motor(shooterMotor) = 0;
      bFloatDuringInactiveMotorPWM = true;
I've notice some erratic behavior if you set a motor, change the bFloatDuringInactiveMotorPWM flag and then set the motor again. Remember that the flag affects all your motors and it seems to only affect motors when you actually set a motor (if you set a motor and then flip the flag, ROBOTC will not apply the coast/float flag until you set the motor again).
You may want to just always float or change the flag back and forth every time before you set any of your motor outputs.
[FTC]: [FTC]: Motor Problems fqzeng FIRST Tech Challenge 3 16-02-2009 19:12
[FTC]: Problems with Motor Encoders? FTC 2891 FIRST Tech Challenge 2 16-02-2009 19:03
[FTC]: Random Error with FTC motor control Xaphiinia FIRST Tech Challenge 2 01-12-2008 15:39
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
[FTC]: [FTC] Motor Controller problems michael714 FIRST Tech Challenge 4 14-10-2008 00:33
