Go to Post What is this... extreme air-keyboarding?...For those about to type, we salute you. - Andy Baker [more]
Unread 07-02-2010, 13:45
mfcarr mfcarr is offline
FRC #3309
mfcarr is an unknown quantity at this point
safety of ATV whip
We are a rookie team considering using a fiberglass ATV flag whip that will be curled in a circle, with considerable potential energy, and then released in the final period to get a hook up to the top of the tower. The manual warns against this, indicating that the inspectors could disqualify a robot if they feel the device is not safe. We have thought of making a track that would guide the tip of the ATV whip so that it is only free when it is pointing almost straight up. Another idea was releasing the tip of the whip by spooling out a string attached to a motor. What characteristics of the lock-release mechanism for the tip of the whip and other safety features do we need to incorporate? Should we abandon this design?
Unread 07-02-2010, 13:54
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: safety of ATV whip
Unless you slow it down or control it somehow, the safety inspectors will probably take notice. My main worry would be 1) What happens if any of the parts involved fail? and 2) What are the chances of it getting jostled lose during competition (going over bumps, getting into high speed collisions)?
The fact that you are questioning its safety now is a good indicator it is an unsafe idea for competition.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 07-02-2010, 14:03
As rookies, you weren't around to watch the flags fly from 2006-2008.
The alliance identification system in those years was a red or blue flag, mounted on a roughly 3' fiberglass pole of the type you describe, put into a 1' long vertical PVC tube on the robot at a certain height. If it bent too much, it went flying. This was mitigated in 2008 when a stopper was added to the flagpole.
If you're worried about safety, your concerns are probably valid.
Your best bet in this case, if you did use it, would be to use the motor reeling out cable that is attached to the hook, which would be securely attached to the pole (or attach a cable to the the hook and another to the pole, and reel them both out). Then you winch the cable back in to climb up. If you go another route, look through CD-Media for examples of the 2004 hangers.
Unread 07-02-2010, 14:39
Meredith Novak's Avatar
Meredith Novak Meredith Novak is offline
no team (Arkansas FIRST)
Meredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond repute
I thought I was so clever when I bought one of these ATV flags at the farm store. It seemed like a good idea until it shattered and we had several fiberglass shard splinters.
Unread 08-02-2010, 12:51
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
Well - seems that the ATV whip is out.
But, there are many types (or grades?) of composite rod that might work for this application. Fiberglass or aluminum tent poles, or fishing rods (not the little flimsy ones) that can practically bend in half.
Has anyone tried anything like that? It's something we may look into more - but if someone else already has then that would be very helpful.
Unread 08-02-2010, 13:13
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I wouldn't say "it's out", but I would make sure there is plenty of safety margin and that you have that safety margin documented for the inspectors. I'd also make sure that the locking system that holds it in place is VERY robust.
___________________
- Tennyson, Ulysses
Unread 09-02-2010, 10:24
JHSmentor's Avatar
FRC #3210 (Falcons)
Agreed!!
I looked into using fishing rods but they are not flexible enough and will definitely break.
Tent poles may work but the larger diameter ones that I found were not flexible enough either. Smaller diameter ones may work but may not be strong enough or durable. So, at this point, I'm not convinced this is a viable option.
Unread 10-02-2010, 09:55
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
So it appears that ATVs are unsafe for more than one reason.
If you are using this to lift an attachment hook off the back/top of your robot, you should consider a much easier and more reliable method. Take a look at your retractable tape measures and figure out why they can be extended as far as they do without "wilting." If you are looking for another example, look up the Mars Viking lander digging mechanism. Now there was a robot!
Safety Reminder: This is why we should all wear safety glasses! The Megan 2207 General Forum 3 05-02-2010 10:06
**FIRST EMAIL**/Safety Animation Award Update & Safety Quiz Mark McLeod FIRST E-Mail Blast Archive 6 10-10-2008 14:58
Post pics of your whip!!! Jetgrindradio00 Chit-Chat 74 11-10-2007 18:47
ATV for sale? Alex Cormier Chit-Chat 3 20-10-2005 23:14
