Go to Post I can see the 2013 Kickoff broadcast now: "Hello Teams. Welcome back. Gracious Professionalism. Here's some homework. Here's the animation. Here's what the actual field looks like. RTFM. Peace." - sanddrag [more]
Unread 08-02-2010, 23:01
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Kit opto encoder resolution?
What is the resolution (in pulses per turn) of the KOP's optical encoders? I need to find out the scaling value to plug into the open VI for the encoders in LabView.
The datasheet says "400-1440" ticks per rotation. This is obviously not helpful. Also, I assume you don't have to specify the quadrature decoding type, right (1x, 2x, or 4x?) I would assume it gets that right without modification.
Thank you for any help.
Unread 08-02-2010, 23:46
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Kit opto encoder resolution?
Last year they were 250, 1x. this year they are either 350 or 360, I can't remember which. I would set it to 350 1x. We honestly don't need more than around 12 counts in 4x decoding, or more for 2x or 1x decoding, since the mechanical error is great enough (especially with a little chain slack) that we could be off by as many as 100 counts using the KOP encoder, depending on gearing.
Kettering Motorsports
Unread 09-02-2010, 03:51
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
360 counts per revolution for this year's KOP E4P-360-250-D-D-D-B encoders
Unread 09-02-2010, 10:43
The decoding type can be used on any quadrature encoder. If you want to count the rising and falling edges on both the A and B channel, choose 4x. 2x does rising and falling edges on only one channel, while 1x only counts 1 edge on one channel. If you are using the encoder for position only, using 4x gets you extra resolution. If you are trying to use the rate function, you'll probably have better results with 1x. Choose whatever makes sense for your application.
One cool thing you can do with the scaling is get the encoder value in a measurement you want to use. For example, if you want to measure angle in degrees, put in a 1 for the scaling. Each tick will then be 1 degree (since the encoder has 360 ticks per revolution). Alternately, you could calcuate using your gear ratios and wheel size that each tick makes the robot move 1/10 of an inch. Put in 1/10 and then you will get the distance the robot traveled in inches.
Unread 10-02-2010, 03:19
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Using the 2x and 1x, raises the question of which edge does it detect? I'm running into problems getting a good count of the encoders and I'm thinking the problem is that we have been using an old IFI robot controller theory of operation.
Our setup on our test setup has the encoder output going to a BaneBot encoder divider. This was done previously to allow us to use hardware to divide the counts of the A channel and latch the direction (B Channel) to preclude any latency issues when reading it on the old controller.
Our final robot will not have the dividers, but to save time, they were left on the practice chasis and the A and B signals were taken from the divider to digital I/O on the cRIO.
In this configuration, we are not getting any counts (getraw() returns 0, 1 -1) regardless of how much we move the robot. However, scoping the outputs of the encoders and the dividers shows that the signals are being generated as expected.
I suspect that the cRIO is getting confused since the B channel is not pulsing, but remains constant while the robot keeps moving. I'll be able to run more experiments on Thursday, with the encoder divider out of the picture to see if things work better.
I suspect it would be good to have the cRIO have a library call that would allow it to take advantage of hardware like the BaneBot divider, but given the current set of interfaces, I do not see how it can be done. I could set up a counter on the A channel, but I don't see how I can get an interrupt when the B channel changes so I can properly apply the direction to the A channel count.
Unread 10-02-2010, 09:53
I believe you can set an external direction input for a counter, which should do what you need.
Unread 06-12-2010, 13:07
Forgive me if this has been asked and answered elsewhere; if so I haven't found it yet:
Per the above explanation, if 1x is reading only one channel, it wouldn't know which way the encoder is spinning, right? So the rate information with 1x wouldn't tell you whether the rate is positive or negative, right?
So if you wanted a rate that contained direction information, would you have to use the 4x?
Unread 06-12-2010, 13:39
There was a long thread (maybe last off-season) that went into a lot of detail about the encoder algorithm.
The 1x, 2x, and 4x only denotes how often measurements are made, the method of measurement is the same. In 1x, 2x, and 4x, the state of the opposite channel is used to determine direction.
Unread 06-12-2010, 13:44
Thank you. I was slogging my way through that long thread but not finding the answer I was seeking.
Unread 06-12-2010, 17:16
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
The number of "ticks" per revolution is found in the part number. The one referenced above has 360 ticks, while the E4P-250-250-D-D-D-B has 250.
Hope that helps
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 06-12-2010, 18:56
I forgot to ask: is the above (bolded) documented somewhere? Before posting here I pulled up the on-line LabVIEW help for the encoder vi but all it said was:
Decoding Type specifies the type of decoding used to decode the quadrature signal. Decoding Type supports three types of decoding for quadrature encoders: 1x, 2x, and 4x.
... which wasn't very informative.
Is there somewhere else that a LabVIEW beginner should be looking for this kind of information?
Unread 11-12-2010, 10:10
AKA: Alex
My team tried to use similar encoders to those in the KOP to read the angle of a swerve module, but we had trouble getting quality readings. If you are trying to do this, my advice is to find another sensor that is designed for this purpose. The KOP encoders to designed to read rotary changes (such as RPM on a gearbox) so that the program can respond accordingly.
Good Luck
-Alex
Screwing Encoder into Encoder Mount? Adrien Electrical 3 25-01-2009 18:14
VEX Shaft Encoder Kit jeffmorris FIRST Tech Challenge 1 19-05-2006 12:23
DPI resolution Branden Ghena IT / Communications 6 17-04-2006 14:43
Resolution of IR sensors Paul Marshall Technical Discussion 2 16-01-2004 14:03
Resolution... Brandon Martus CD Forum Support 9 15-05-2002 18:49
