Go to Post New mentor joins one team and ends up impacting several in the same region. I like that. :) - Travis Hoffman [more]
Unread 09-02-2010, 11:16
nievz23 nievz23 is offline
nievz23 is an unknown quantity at this point
rack and pinion problem
a rack and pinion is used to drive a gate mechanism. The pinion has module of 12, 11 teeth and a pressure angle of 25. Solve for the details for each gear profiles.
Shaft diameter = 30 mm
Hub diameter = 60 mm
Keyway = 8x8
Rack and Pinion Drive? bmarick Technical Discussion 2 06-01-2009 22:16
Rack and Pinion DarkFlame145 Technical Discussion 0 02-04-2008 20:30
Rack and Pinion/Motors and servos psniffler Motors 7 25-01-2008 16:16
Rack & Pinion SHS Blue Devils General Forum 5 12-01-2008 17:59
rack and pinion. greencactus3 Pneumatics 17 04-11-2004 23:24
