Re: Program Delay
There exists a way to program your robot to do pretty much anything. You have to define the conditions you want things to operate in. For instance:
You have Switch A, and Switch B. If Switch A is on, then pressing Switch B causes action X to happen. If Switch A is off, then pressing Switch B causes action Y to happen. You can also cause a switch to perform one action, such as turning a motor on, then activate a timer, and when the timer expires, do something else. |
| A boolean delay | m3rc1l3ss | NI LabVIEW | 1 | 18-02-2009 21:51 |
| cRIO Program Delay | bomber7 | Programming | 2 | 29-01-2009 21:35 |
| Delay | jasonpeinko | Programming | 8 | 18-01-2008 15:56 |
| Delay in the segment of the program | Lessa | Programming | 1 | 10-02-2006 02:06 |
| Delay | Gal Longin | Programming | 1 | 09-12-2004 10:37 |
