Go to Post You enjoy your pepperoni pizza, I'll enjoy my cheese and peppers, and we can both agree that people that like pineapple on their pizza, while strange... are completely entitled to their opinions. - Andrew Schreiber [more]
Unread 06-02-2010, 14:29
Labot2001's Avatar
Labot2001 Labot2001 is offline
FRC #3332
Labot2001 is an unknown quantity at this point
Anti-tip or Self-Righting Mechanisms?
Has anyone come up with anti-tipping or self-righting mechanism technologies? It would be great to see to some examples. We're a small rookie team and haven't really given this aspect of the build too much thought
TIA
Unread 06-02-2010, 15:38
Re: Anti-tip or Self-Righting Mechanisms?
I don't think there are too many anti-tip mechanisms this year. The GDC has ruled that you can't go beyond the frame perimeter to avoid tipping, just to self-right.
Unread 06-02-2010, 19:27
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
There is one anti-tip technique that any team can do: low center of gravity.
Our team hasn't though about any sort of righting mechanism, we are just trying to keep our CoG low and to have a short bot.
Unread 06-02-2010, 19:48
Chris is me's Avatar
AKA: Pinecone
Not a mechanism, but fair enough. "Everyone" is going for that, hopefully.
Anti-tip is the lowest priority for 2791. The simplest way to integrate a righting mechanism is to integrate it with the hanger, but the hanger isn't load bearing on our robot. There's no time or resources that wouldn't be better spent elsewhere for a self righting mechanism.
We only expect to go over the bumps maybe twice a match though, and we're not tipping without the help of the 45 degree angle.
Unread 06-02-2010, 19:53
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
Agreed.
And:
Necessarily, how many times must a team cross the bump in a single match?
Unread 06-02-2010, 20:14
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
If you had the weight to spare (yeah right), you could have a 5-10 LB counter-weight mounted on a slide controlled by the gyro. It is complicated and doesn't give you much advantage, but doable.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 06-02-2010, 22:28
DonRotolo's Avatar
Back to humble
FRC #0832
One of the best strategies would be to avoid tipping over in the first place. Build a robot that can go over the bump without tipping, and make sure the drivers know how to do it without tipping, every time.
As a rookie team, I think you will find that driver practice is the most important thing you can give the team. So, forget a self-righting mechanism (or, build a Weeble) and put your energy into more important things.
My 2 cents.
Unread 06-02-2010, 23:17
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
If you have a wide-axis chassis, don't plan to go through the tunnel, and have a low enough center of gravity, you CAN be a weeble. Just put semi-circular roll bars at the end on each short side. With a low enough center of gravity, your bumpers stick out far enough to self-right the robot.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 06-02-2010, 23:48
blayde5's Avatar
blayde5 blayde5 is offline
AKA: Abhi
FRC #3504 (Girls of Steel)
blayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of light
115 is basically building a second structure made out of 1x1 aluminum shaped like a house (it's more of a passive structure). The idea is that because of the bumpers, the robot won't fall completely flat.
the wedge at the top of the house would provide an alliance member enough leverage to just bump into us and flip us over.
Unread 09-02-2010, 04:27
Tony.Wu Tony.Wu is offline
Carnassial
AKA: Dave The Mechanic
Team Role: Animator
Tony.Wu is an unknown quantity at this point
Send a message via MSN to Tony.Wu
One team used a domed top.
Unread 09-02-2010, 09:56
AKA: Pinecone
Something else to consider: Design is an iterative process. Maybe you can see if you'll need one once your robot is all built together. It's trivial for my team to bolt on a roll cage on top of our frame halfway through the season if the need arises, but not having it on keeps the tunnel open as an option (albeit not one to be used much) so nothing's being designed unless we need it. If your robot is similar, you could consider an option like this.
Unread 09-02-2010, 12:05
Jordan2389Diaz's Avatar
Jordan2389Diaz Jordan2389Diaz is offline
Grant me your power...Verto
FRC #2389 (Pirate Robotics)
Team Role: Tactician
Jordan2389Diaz can only hope to improve
Yeah my team 2389 is not building anything to right ourselves which just hope in our driver's skill that we do not flip over.
Lord is my Shepherd I shall not want-Psalms 23
Unread 09-02-2010, 12:09
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
While I don't believe our robot will tip over on its own, I believe there will be enough defense at the Bump to cause robots to flip.
Hence, we will have a self righting mechanism.
___________________
- Tennyson, Ulysses
Unread 09-02-2010, 13:27
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Lots of good advice here, but this has to be the best I read. Just because you don't plan on dealing with the bump or plan to be careful around it, others might not do the same. They might take you to the bump or push you around while your on it. Self-righting devices could become key to some regionals that are known for their aggressive defense while others will rarely see a robot tip. Guess its good to know what to expect, if only we ever really could.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 09-02-2010, 13:40
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Agreed 100%. All you need to do is examine the CG of your robot, and figure out how much force/displacement you need before the CG is going to right itself the rest of the way.
Couple with a cage that prevents the robot from falling on its back, a pneumatic piston at the proper height, pressure, and stroke will do wonders in self-righting mechanisms. Same with a double window motor actuated arm mounted at about bumper height.
If you fall flat on your back, well, that's a whole different story. Still manageable though.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Anti virus Schnabel Chit-Chat 29 09-06-2007 13:52
Self-righting Tim566 General Forum 33 04-03-2006 09:43
Image Discuss: Self-Righting CD47-Bot Robot Showcase 14 25-02-2003 13:41
Anti-V Day Mike o. Chit-Chat 17 15-02-2003 20:35
Righting a robot... archiver 2001 2 24-06-2002 00:26
