Go to Post You can have any color robot you like, so long as it stays that color. So you shouldn't have to worry unless you have a chameleon bot. - Kevin Sevcik [more]
Unread 09-02-2010, 13:45
Racer26 Racer26 is offline
Re: The increasing amount of pre-canned code
You raise an interesting point. I think a large amount of the disdain aimed at NI is due to perceived unreliability of the cRIO. I think this is less a function of ACTUAL unreliability, and more a function of the cRIO being several orders of magnitude more powerful than we need it to be.
We went from an 8bit MCU running at 20MHz with a few K of ram, to a 32bit processor, running at 400MHz with a boatload of ram, for the SAME application. Yes, there were some teams that had started to push the limitations of the IFI system, but the cRIO seems a bit like driving a finishing nail with a sledgehammer. Sure, it works, but is it REALLY the right tool for the job?
Hartford Canned Goods Drive easponge General Forum 0 24-03-2009 20:50
pic: Canned Food Drive Flyer for NYC Regional daryl Extra Discussion 9 06-03-2009 19:31
can we control the amount of air to control the speed of the cylinder? Team2339 Pneumatics 22 11-02-2009 15:33
Friction-increasing substances nayer247 Technical Discussion 15 29-01-2009 12:10
Amount of Force to lift the bridge? archiver 2001 2 23-06-2002 23:21
