Go to Post This is high school robotics for fun and education. Let's try and keep it that way. - Rod [more]
Unread 08-02-2010, 18:57
kennypu kennypu is offline
FRC #2467
kennypu is an unknown quantity at this point
Re: outputting data to DS's usermessage
i see, I just needed to know the class name where I needed to get the functions from. So just use the functions from DriverStationLCD correct? Thanks x]
Unread 08-02-2010, 19:02
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
DriverStationLCD *myDS_LCD = DriverStationLCD::GetInstance();
Unread 08-02-2010, 20:31
bcieslak
Posts: n/a
Originally Posted by jhersh View Post
when we do this we get a no robot code error on the driver station...anybody else have this problem??
Brian
Unread 08-02-2010, 20:34
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Yeah there is a bug in WPILib right now that crashes any user code trying to get a DriverStationLCD. If you revert to the version released at the beginning of the season you should be able to use it until a fix is released. Just download the old workbench update and install it
Unread 08-02-2010, 22:43
AKA: Brad
#0190 ( Gompei and the Herd)
There seems to have been a compiler or linker bug that was causing a static const int variable to not initialize correctly that just started happening. I posed a new version here:
http://first.wpi.edu/FRC/frccupdates.html
That seems to fix the problem. That's the only change in this version so there's no need to update if you aren't using the DriverStationLCD class.
Brad Miller
Robotics Resource Center
Unread 09-02-2010, 13:39
bcieslak
Posts: n/a
thanks for the tip Radical Pi ..we pulled up the old DriverstationLCD.cpp file, fixed a type mismatch in the .h file that gave a warning and rebuilt. All is well in the world again (or at least until another update comes out).
BC
Unread 09-02-2010, 14:30
BC
It's already out, to fix this issue: http://forums.usfirst.org/showthread.php?t=14573
Unread 09-02-2010, 21:19
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
The fix works but breaks the Camera. LCD is working great.
Unread 10-02-2010, 18:39
yoyodyne yoyodyne is offline
AKA: Greg Smith
FRC #0116 (Epsilon Delta)
yoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to behold
We had the same problem so we replaced each instance of kLineLength with 21 in WPiLib and recompiled WPiLib. Not an ideal solution but it works. We have to modify WPiLib anyway to fix other problems and to get it to calibrate the gyro and one of the accelerometers in parallel and added a method so we could get the gyro rate to support a closed loop "arc turn".
I am still interested in seeing an example of how to use the Printf function to print to the dashboard user data so we can use the logging function since we are using the serial port for the jag CAN bus, not the driver station LCD. When we try to add the Printf output to the high or low priority dashboard packer we get errors in the DS display. I guess it's time to bite the bullet and figure out exactly how the data structures are configured. Does anyone know if there is documentation on this besides looking at the DS labview code?
Thanks,
Greg
Unread 10-02-2010, 20:49
You can only use the Printf -OR- the Add* + Finalize functions... not both on the same packer at the same time (without calling Finalize and waiting for a new DS packet). To use the Printf, simply stop calling the other functions on that packer. Then on the Dashboard side, instead of calling "unpack from string" on the received string, and instead use the string as is and write it to a file or an indicator or whatever.
-Joe
Unread 11-02-2010, 22:15
AKA: Greg Smith
Thanks Joe.
How do you wait for a new DS packet?
Unread 12-02-2010, 02:41
Thanks Joe.
You can call IsNewControlData() on the DriverStation object.
Generally this shouldn't be necessary for this use case since usually the dashboard is expecting one or the other... so your robot program should only be using one or the other.
The only case I can see where you would use this is if you would like to print one set of messages each time a packet goes out, then you could use this to tell when that happens.
-Joe
Voltage not outputting to the Drivers Station Ryutso Electrical 8 09-02-2010 11:39
Periodic Task Data --> Robot Data Kahn! NI LabVIEW 3 10-02-2009 19:38
Sending user data, parsing user data. demosthenes2k8 NI LabVIEW 3 30-01-2009 13:51
PWMs not outputting in Autonomous 937Programmers Programming 15 08-02-2007 21:25
