Go to Post You have not only joined a robotic competition, you will discover that you are becoming a member of a very large and wonderful family. The more years that you participate, the larger your FIRST family will become. - Car Nack [more]
Unread 09-02-2010, 14:36
Roy880 Roy880 is offline
FRC #1577
Roy880 is an unknown quantity at this point
"Painting" on the field
When our robot turns it leaves sort of "drift marks" on the field.
Is it legal?
Unread 09-02-2010, 15:08
Prash R.'s Avatar
Prash R. Prash R. is offline
Prash Tank
FRC #0025 (Raider Robotix)
Prash R. is a jewel in the roughPrash R. is a jewel in the roughPrash R. is a jewel in the rough
Send a message via AIM to Prash R.
Re: "Painting" on the field
I think it is illegal. Sorry. One of the rules states, and i am paraphrasing, the robot cannot do anything that damages or alters the field in anyway
Unread 09-02-2010, 15:09
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
You need to figure out if you are damaging the carpet or leaving any residue behind. If your marks just come from changing the angle of the fibers in the carpet so they reflect light differently (kind of like you see with the rolled grass patterns on baseball fields) then you are probably fine.
If you are leaving a trail of burned rubber and molten carpet in your path you should consider changing something.
Check for tears or fibers in the carpet that are pulled out. Also be sure you are not leaving peices of your wheels behind. Those are the kinds of things that will make your inspection difficult.
Good luck!
Rob
Unread 09-02-2010, 15:10
Roy,
Is the residue that same color as your wheels or are you merely rubbing off surface contamination?
Unread 09-02-2010, 15:13
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Just to add to the discussion a bit, some carpet damage over the course of a regional from robots tipping, hard defense, etc... I don't think I've ever been to an event where the carpet didn't have a scrape or ten on it by the end of eliminations.
But, if the Damage is ruled as intentional, or due to the design of your robot you probably will not pass inspection or you will be carded sometime during your event. I'd say that leaving skid marks on the carpet under normal conditions is illegal.
-Dustin Benedict
What's the difference between "The Great Attractor" and "Dark Flow" Woody1458 NASA Discussion 0 04-05-2009 22:17
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Is the "sort by uploader" supposed to work in the "who am I" gallery? Greg Ross CD Forum Support 1 07-10-2002 07:05
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
