Go to Post It sounds like "whirr" if you do it right, and "clack clack grunge snap @$@%^!!" if you don't. - dtengineering [more]
Unread 09-02-2010, 09:43
blhenze blhenze is offline
Bernie H
FRC #2333 (Sapulpa Chieftain Robotics)
blhenze is an unknown quantity at this point
LabVIEW/Jaguar Help
The Software has been updated. The cRIO has been updated. The instructions were followed to the letter for implementing Simple Motor Control. The program compiles and downloads without an error. Under the "Watch Mode" everything functions without an error. However, the Joystick does not cause the motor to run and the Jaguar flashes yellow (never going solid).
All of the wires have been tested for continuity. All parts have been systematically swapped out. Does anyone have any suggestions/help as to why the Jaguar never goes solid and the motor doesn't turn?
We can't go any further until we resolve this issue.
bhenze@sapulpaps.org
Unread 09-02-2010, 09:57
Re: LabVIEW/Jaguar Help
What is the RSL on the Digital sidecar signaling?
And the other Digital Sidecar power status lights?
What do all the Driver Station status lights on the Diagnostics tab indicate?
Of course, is your robot Enabled?
Some typical reasons for a Jaguar blinking yellow:
  • Robot not Enabled by the Driver Station (RSL tells all)
  • Jag PWM cable not connected to the white PWM outputs, reverse connections, or possibly bad cable
  • Digital Sidecar not receiving power
  • Code does not Open the PWM the Jag is connected to.
Of course there are many more possible reasons, such as, out-of-date software and cRIO image, which you already checked.
Did you mean to say you are using the "Motor Control Example" ?
My version of LabVIEW doesn't have a "Simple Motor Control" example, but you might be using something else as your baseline.
What instructions did you follow, so I can walk through them?
Unread 09-02-2010, 13:19
Bernie H
Finally, all the right questions fell into place - it is now working - Thanks!!!!
Unread 09-02-2010, 15:56
A brief explanation of what you did to make it work would be appreciated.
labview delay help glitch NI LabVIEW 3 08-02-2010 09:37
Labview help pedro696 General Forum 14 06-02-2010 19:34
HELP!!!! we need help w/ compressors/pneumatics for teleop/autonomous in LABVIEW rokenboker NI LabVIEW 9 05-02-2010 17:10
labview comressor help!! mole NI LabVIEW 15 03-02-2009 14:11
help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) liad LabView and Data Acquisition 8 18-01-2006 12:20
