Go to Post So yeah I love the minibot because it was a great vehicle to promote our team, make new friends, and possibly make sure a team makes it past their 1st or 2nd year. - Mr V [more]
Unread 07-02-2010, 13:18
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: pic: Team 2502 Chassis Teaser
Originally Posted by Techgirl675 View Post
For sake of comparison our chassis with 4 CIMs, mechanum wheels and all 4 gear boxes is less than 35 pounds...
For what it's worth, we've gone the 80/20 route. While it's great for prototyping and testing, we've found it's far too heavy for competition use. We've since switched to welded thin-wall steel tubing and it seems to work quite well.
WOW!
4 Cims is 10 Lbs.
4 6" Mecanums is 6.2 lbs.
4 gearboxes is anywhere from 6-10 lbs.
Making your frame only
12.8 lbs. max
Our frame is pretty bare essentials out of aluminium and its at 18lbs.
Unread 07-02-2010, 13:42
Techgirl675's Avatar
Techgirl675 Techgirl675 is offline
FRC #0675
Techgirl675 will become famous soon enough
Send a message via AIM to Techgirl675
Originally Posted by Jeffy View Post
WOW!
4 Cims is 10 Lbs.
12.8 lbs. max
We have a welded steel tube chassis and it is only 10 pounds including all of the supports.
"You're doin it wrong!"
http://techhighteam675.com/
Unread 07-02-2010, 15:52
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
That's pretty cool. Though I honestly don't know why it has to be that light for it to be considered a "good" or a balanced robot
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 07-02-2010, 15:57
FRC #0675
It really doesn't need to be, it just happens to be what we decided to use for strength and the light weight.
Unread 07-02-2010, 17:23
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
Would you mind sharing the size and alloy of the pipe?
We have aluminum and steel welding machines here. and steel welding is so much easier.
Unread 07-02-2010, 17:40
FRC #0675
Last year we used 1 inch steel tube and this year it is 3/4 inch with 1/2 inch supports. Everything holds up great!
Unread 07-02-2010, 18:03
keehun's Avatar
Team Captain
AKA: Keehun Nam
Haha cool. Sorry if I sounded like I hated you or something. I don't!
But someone earlier brought up low CG -- and yes, that's one of our main focuses. We are doing direct drive with Banebots Planetaries and we're trying to achieve super low CG.
Unread 08-02-2010, 07:28
dragon72950 dragon72950 is offline
FRC #0675
dragon72950 will become famous soon enough
I will weigh it this coming monday.
And we do have a very interesting wide-configuration that will be super weird but we hope to have work out!
And no swerve this year. We thought that whatever we could make would have too low of a clearance to go over the bump.
Hm, did I give too much away?
well interested to see how much it weighs
Unread 08-02-2010, 07:52
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
One of the heftiest frames I have seen this year.
I'd be interested in the wall thickness and alloy you are using as well.
Unread 08-02-2010, 09:03
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Welded 4130 steel (maybe 1020?) is probably the lightest possible frame construction barring composites, which are cost-prohibitive for FIRST. Alloy steel is better than 6061-T6 aluminum in nearly every regard...
I've made FSAE car frames with largely .065"/0.045" walled round tubes. 0.035"x0.750" square tube would be plenty strong enough for a FIRST robot. And no strength loss from welding FTW! Unfortunately my team didn't have the facilities to make a frame like that this year
Unread 09-02-2010, 13:49
team1718 team1718 is offline
FRC #1718
team1718 is infamous around these parts
How heavy is heavy? With gearboxes, motors, electronics, the calculated weight is 50lb...
And I can lift this with one arm. Easier to lift with two arms..
your really going to regret using 80/20
Unread 09-02-2010, 14:12
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
Team 1208 loves 80/20.
Our completed robot this year has a kicker, lifter, ball collector and climbs the bump. It just weighed in at 116 pounds.
Unread 09-02-2010, 17:34
EricH EricH is online now
Can you provide a reason for saying this? If you have a valid reason (bad experience, finicky connections, stuff like that), then by all means post it. If you're just saying this to say it, then it might be better not to say it.
Unread 09-02-2010, 18:11
keehun's Avatar
Team Captain
AKA: Keehun Nam
We've been using 80/20 since our rookie year without a problem. (Well we've had problems but it was a human-fault). So any evidence or warrants behind your statement?
Unread 09-02-2010, 19:41
Bob Steele's Avatar
AKA: Bob Steele
80-20 can be a fine material to use for a frame
so can many other things... One of the neatest things in FIRST is that there is no ONE RIGHT WAY to do anything!!
My own experience with 80-20 was from my own mistakes early on...
I didn't make sure everything was always tight.... or use lock tite on the connections... When my old team started using 80 20 by bolting through and making our own brackets we had much better success...
I really like the comments I am hearing about using steel tube... I think we will investigate that next year.... sounds like an interesting solution....
thinner steel vs thicker aluminum
Ease of welding.. vs difficult welding...
Worth looking at.... it must work.... thousands of bicycles and cars use it
thanks for the great suggestions...
Your 80-20 frame looks pretty cool!!!
good luck and we will see you on the field!!
pic: Team 935 Chassis Teaser railerobotics Extra Discussion 24 08-02-2010 15:24
pic: Team 2502 Driver Station keehun Extra Discussion 2 12-04-2009 15:24
pic: Team 2502 Robot 2009 keehun Extra Discussion 4 18-02-2009 20:55
pic: Team 665 REAL Chassis, Kinda-Teaser Greg Peshek Extra Discussion 13 25-01-2008 08:14
pic: Team 1676 Chassis Teaser Spiffizzle Robot Showcase 10 28-01-2006 23:53
