Go to Post We had an autonomous bug last year . . . Funnily enough, this worked real well and other teams were asking us for this "feature." - dragoonex [more]
Unread 09-02-2010, 18:13
zip100 zip100 is offline
FRC #0640
zip100 is an unknown quantity at this point
Defective Ethernet Port on FRC Laptop
Our laptop provided with the kit has a defective ethernet port. If we connect an ethernet cord to the laptop it becomes loose. The only way we can hold it in place is by using masking tape. It works but over time it still gets loose. Does any one have the same problem as us? Also, does anyone have a solution to our problem? We are open to any suggestions and ideas, thank you for your time.
Unread 09-02-2010, 18:43
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: Defective Ethernet Port on FRC Laptop
are you sure it is not the cable? the clips on those type cord often break. try another cable.
Unread 09-02-2010, 21:43
From http://www.usfirst.org/frccontrolsystem
Hardware
CTL for Classmate hardware help - Submit a ticket online. Please remember to include the Serial # or Asset Tag # of your Classmate PC, your contact info, and a shipping address if a repair is needed. We also recommend that you add "support@ctl.helpserve.com" to a white-list if you have a spam blocker installed.
cRIO's Ethernet Port Randomly Disconnecting? TD912 Electrical 5 17-01-2010 09:30
How to prevent broken ethernet port on DS Bharat Nain FRC Control System 32 18-03-2009 11:25
Driver etation ethernet port 2 died! RossC Programming 6 15-02-2009 01:13
Dell laptop serial port notquitehere188 Programming 18 26-10-2006 22:32
Horror Story - Laptop com port again Lloyd Burns Programming 3 17-03-2003 07:33
