Go to Post If only more people could have the same attitude toward FIRST as they do toward their fellow teams! - Jaine Perotti [more]
Unread 09-02-2010, 02:50
Bob Holmstrom Bob Holmstrom is offline
FRC #2411
Bob Holmstrom is an unknown quantity at this point
NXT Ultrasound sensor?
Has anyone tried to use the NXT ultrasound sensor? Does a Labview/FRC vi exist for the sensor?
Thanks for any help!
Bob Holmstrom
Mentor Team 2411
Unread 09-02-2010, 08:23
Re: NXT Ultrasound sensor?
It isn't an I2C standard sensor, so you'd have to find some other way of interfacing it.
Unread 09-02-2010, 15:08
FRC #2411
OK - There is a ultrasonic vi in the example code provided that uses a sensor labeled SRF04 - There seems to be quite a number of ultrasonic sensors out there that use that part number, but the information at http://www.acroname.com/robotics/inf...h/srf.html#e11 that describes the devantech SRF04 and SRF05 seems to resemble the information in the ultrasonic VI. Has anyone used this sensors in a FRC application?
Bob Holmström
Unread 09-02-2010, 18:18
Electrical Engineer
Rookie Year: 1995
Mark,
Actually, the NXT ultrasound is I2C. You may be confusing this with the VEX ultrasound which is not (it's discrete digital).
Hopefully, this document should give you everything you need.
Regards,
Mike
Mike Betts
As easy as 355/113...
[FTC]: NXT-G programming ivybotter FIRST Tech Challenge 4 10-10-2009 12:02
Frozen NXT Brick. devinejohnny General Forum 2 05-11-2008 21:34
Lego MindStorm NXT Gamer930 Lego Mindstorm Discussion 1 10-07-2006 09:21
pilot NXT opportunity RoboMom FIRST Lego League 0 08-05-2006 10:32
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
