Go to Post Not that I'm doubting you, but where is it bugged? The exterminators are in the house. - Greg McKaskle [more]
Unread 09-02-2010, 18:20
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Reverse flow direction on SMC valves
I won't swear to this, but here is what I believe:
The valve is a pilot operated valve, with a small pilot solenoid mounted on the end. This pilot solenoid must have access to pressure at all times for the valve to function. It receives this pressure from a small port within the P port. If at any time, there is no pressure on the P port, the valve will cease to function. So, your proposal might work since it looks like you will always have pressure on the P port, but I don't know what will happen as the valve shifts and the pressure drops between positions.
Former Mentor Team 1771
Former mentor Team 4509
Need help with SMC solenoid valves Ed Law Pneumatics 6 04-02-2010 06:43
HELP last years SMC valves nevereverregret Pneumatics 1 11-02-2009 21:43
Parts Usage Flow Chart Karthik Rules/Strategy 6 05-01-2009 16:47
Flow Switch question? Inert Entry Pneumatics 1 28-02-2005 16:22
Organizational Flow Chart Paradox General Forum 2 03-11-2002 21:11
