Go to Post Don't just build a robot; build up your community. - Pat Arnold [more]
Unread 09-02-2010, 19:00
JoeyTNT280's Avatar
JoeyTNT280 JoeyTNT280 is offline
Scouting
AKA: Joey
FRC #0280 (TnT)
JoeyTNT280 is an unknown quantity at this point
Send a message via AIM to JoeyTNT280
LABVIEW
Is there any other way to program other than using the basic framework?
I no longer have the time to go through 50 posts and such so sorry if this is posted already. Please respond ASAP.
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 10-02-2010, 00:22
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: LABVIEW
You'll have to be more specific.
The Basic Framework from last year is no longer in use. (We use a modified Advanced Framework, but use fancy functional globals to call devrefs by name, instead of wiring them from Begin to the other VIs).
Please tell me if I misinterpreted what you're trying to say.
-- Marshal Horn
Unread 10-02-2010, 20:23
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
Re: LABVIEW
O.K, the technical answer is NO, you can not use the framework from last year on this years robot.
HOWEVER: there are a couple of things that you can use which look very similar, i.e Teleop, and Autonomous Independent. The Begin and Finish vi's are just the opens and closes respectively. There should be no difference in Teleop, or in Autonomous this year, or at least for our team it wasn't.
good luck and hopefully this helped
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
Last edited by Egg 3141592654 : 10-02-2010 at 20:23. Reason: framework != fromework
Unread 11-02-2010, 16:30
JoeyTNT280's Avatar
Scouting
AKA: Joey
FRC #0280 (TnT)
Re: LABVIEW
Ah I see, thank you for the responses and I have decided to learn the new framework.
-Joe"y" Horth
Programming
Scouting
Pnuematics
TnT 280 Robotics
C++ in LabView dpeterson3 Programming 6 17-02-2009 19:14
Labview 8.5 vs. FRC Labview 8.5 pyr0b0y NI LabVIEW 0 01-02-2009 22:20
LabVIEW vs C/C++ 3DWolf Programming 11 05-12-2008 09:14
Labview tseres Programming 2 23-05-2007 00:27
Labview Phreakuency LabView and Data Acquisition 6 14-01-2006 01:14
