Go to Post However, I think the laws of physics indicate that doing so is going to be very difficult at best. - EricH [more]
Unread 09-02-2010, 19:34
Must Be Drama Must Be Drama is offline
Must Be Drama is an unknown quantity at this point
Re: We Got Mech Shifting But We Need help with Regular TURNING
Originally Posted by Vikesrock View Post
The bigger problem is the constant 0 wired into the spin input on the holonomic drive VI.
Describe in English how you want the spin controlled (what joysticks, buttons, etc.) and we may be able to help you implement it in Labview.
ok; we are trying to do regular drive forward backwards turning left turning right
then when we press button 1 it will do shifting/crabbing
Unread 09-02-2010, 20:00
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Ok, your true case looks alright then. I would suggest moving the 0 into the case for clarity purposes, but this is not absolutely necessary.
It sounds like your problem is with your false case. What does your false case look like right now and what problems are you having with it? Your first post mentions that "the wheels are inverted", but I'm not sure what this means.
Unread 09-02-2010, 20:13
our false only has arcade in it; is there a better or am i doing it wrong?
Unread 09-02-2010, 20:15
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
OK, so what is the problem you are experiencing? What does "the wheels are inverted" mean?
Unread 09-02-2010, 20:20
when we go forward the left side goes backwards
Unread 09-02-2010, 20:32
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Are you sure that you have the correct axis wired into the correct terminal on the Arcade Drive VI?
That's the only thing I can think of. If you didn't properly invert the motors when opening the drive in Begin.VI I don't think your holonomic VI would drive and strafe properly.
Regular Xbox Controller...HELP! lostandconfused Control System 1 13-02-2007 14:29
Need shifting transmission layouts/ideas sanddrag Technical Discussion 6 13-01-2006 13:24
Turning problems, we need suggestions PLZ Oumonkey Technical Discussion 44 20-07-2005 12:21
New to C but not to basic, need help on autonomous cdennisxlx2 Programming 4 02-02-2005 03:38
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
