Go to Post Sustaining an FRC team is really hard! - Jared Russell [more]
Unread 09-02-2010, 19:48
WarrenPW WarrenPW is offline
FRC #2085
WarrenPW is an unknown quantity at this point
Windows "Malfunctioning USB Device" error with Psoc IO Board
Hello,
Recently I have been having trouble with the Psoc IO board. I know this sound like a driver issue but I don't think it is. The board was working up until a day ago, and now when it is plugged in, windows gives an error about a malfunctioning USB Device on both our programming computer an the classmate. Do you think we will have to get a replacement? If so, where would we go to get one?
WarrenPW
Team 2085
Unread 10-02-2010, 00:20
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Windows "Malfunctioning USB Device" error with Psoc IO Board
You could try re-applying the IO board update from the DS update (uninstall then re-install). Also, make sure there isn't anything shorting the io board (unplug it from the breadboard, check for metal shavings, etc.)
If you need a replacement, most likely you will have very little time to test it, if any. Our team ordered a new one since we lost the kit one and it took at least a week and a half to get here. In the meantime the DS can simulate the digital and analog inputs of the io board through the IO tab.
The product page for the IO board is here
Unread 11-02-2010, 18:53
FRC #2085
Thank you for the suggestion, but when I run the update again to uninstall it, it doesn't give me the option to. I tried manually removing all the cypress drivers, but it still gave me the errors. What do I need to do to uninstall the update?
I do believe the software is the trouble, though, because when I plug it into a computer without competition software, it doesn't give the error.
WarrenPW
Team 2085
Need help with "Undefined symbol" error mikets C/C++ 14 21-01-2010 22:39
IFI Loader error "No programming board found" sjeddie Programming 4 07-07-2008 20:51
"Code Error" with RegisterRepeatingTimer d235j Programming 4 27-02-2008 21:51
"Signaling Device" reciever location? FreakyAntelope General Forum 9 06-01-2008 01:50
Congratulations is spelled with a "T" and not a "D"!! Elgin Clock Thanks and/or Congrats 55 09-03-2007 13:24
