Go to Post Who has time for boredom? - Dr Theta [more]
Unread 09-02-2010, 14:40
alex42 alex42 is offline
FRC #1072
alex42 is an unknown quantity at this point
Driver Station Delay
Our Driver Station responds strangely slowly to button presses on the joysticks. When watching on the Setup tab, there is often a (usually small but) noticeable delay between when a button is pressed on a joystick and when that joystick's name turns blue and asterisks appear next to it. This is usually followed by a similar delay between when the DS acknowledges a button press and when the robot responds to it.
Unread 09-02-2010, 17:26
Re: Driver Station Delay
Make sure that you aren't running multiple driver stations on the same computer. This is usually done accidentally by Fast User Switching. The new DS update will prevent this BTW.
If you aren't sure, reboot the classmate going directly to the driver account. If it still happens, can you quantify the delay?
Greg McKaskle
Unread 09-02-2010, 20:14
FRC #1072
We tried rebooting the DS. It might have made a difference temporarily, but it's hard to be sure. The delay varies between less than I can see to, on rare occasions, more than a second.
Driver Station? qpang FRC Control System 2 27-01-2010 16:59
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver station... the man Control System 16 06-01-2010 21:06
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
driver station corps FRC Control System 5 06-08-2009 20:44
