| View Poll Results: What are planning on doing? (select all that apply) | |||
| Hanging from the tower |
94 | 66.67% |
| Hanging from an alliances' robot hanging on the tower |
29 | 20.57% |
| Allowing alliance to hang from us |
33 | 23.40% |
| Sitting on the tower |
14 | 9.93% |
| Nothing, just score goals |
42 | 29.79% |
| Multiple Choice Poll. Voters: 141. You may not vote on this poll | |||
#16
Re: Who is hanging and how?
Something along the lines of this
#17
Carbon fiber grappling hook + carbon fiber telescoping arm.
#18
Lifting is best solved by a TENSION solution. Ramps are compression based.
Compression is high mass and produces TORQUE. Tension is self aligning and LOW MASS. Think cables and synthetic fiber lines. -Dick Ledford 3135 Robbotic Colonels |
#19
A combination of pneumatics and a ramp deploying mechanism.
Technically 27.xx degrees. ![]() |
#20
-Dick Ledford |
#21
No we only cross the bump. We want to keep the arm low and close to the robot to help keep a low CG.
Telescoping should be easy how we do it. Connecting the bottom of the upper(inner) tube to the top of the bottom(outer) tube with surgical tubing. We'll use a worm transmission to hold the upper tube down inside the bottom tube against the tension, unwind the worm to release tension, allowing the arm to spring up, then after hooking, re-wind the worm to lift our robot up. |
#22
To lift a robot onto your robot that is on the platform?
#23
How are rampbots 4 pointers? |
#24
If the other two bots climb your rampbot to become ELEVATED, they get 2 points each.
#25
The only way I could see a ramp bot being worthwhile would be if the ramp bot could hang from the elevated bot, but this would most likely just result from the elevated bot being pulled down and landing on the rampbot. My team is going with a telescoping rod with a grappling hook on the end. The hook detaches and the bot is winched up. Incase that somehow fails, we have a side hanger being made too as a back-up. |
#26
And the robot is touching the tower. It may be tricky(but not impossible) to get the second robot you are trying to elevate in contact with the tower if the first robot doesn't quite fit and has to hang off.
#28
Team 58 - The Riot Crew will be hanging. In fact we tested our robot tonight. Video can be seen on youtube
http://www.youtube.com/watch?v=9TToKIpXpVI We hope to make it a little faster but it works. |
#29
Tested the hooks the hooks tonight, nice and light weight...
#30
If our team ever gets off our little #25 chain tangent, we'll finally get back to making our lifting arm work with 3840-pound breaking strength Dyneema. We snapped our 1050-pound Spectra A spearfishing line, so our mentor has typecast the material as being weak, and he's trying to get it to work with #25 chain. But once we get back onto the Dyneema (since the chain failed tonight, even faster than the Spectra), we'll be set up to support two robots and ourselves.
| Hanging robots and <G31> | ssa3512 | Rules/Strategy | 20 | 01-13-2010 05:22 PM |
| 2007 Indy 500 - Who is going and who will be watching? | Cynette | Chit-Chat | 20 | 05-27-2007 09:30 AM |
| YMTC: Bluabot and Redabot hanging? | Natchez | You Make The Call | 15 | 03-23-2004 01:42 AM |
| pic: Team 340 Hanging and Uncapping | CD47-Bot | Robot Showcase | 1 | 02-23-2004 11:02 AM |
| Starting position and hanging clarification | Don Wright | Rules/Strategy | 2 | 01-10-2004 02:21 PM |
