Go to Post dont be afraid of new technology. embrace it and experment with it figure out the problems on the way and then tell us about it so it gets easier. - Tytus Gerrish [more]
Unread 09-02-2010, 21:00
Lumit Lumit is offline
FRC #2521
Lumit is an unknown quantity at this point
Gyro spinning while stationary
So... We plugged in last year's Gyro (veteran team), and the indicator on the control panel is just spinning around like crazy while it's just sitting there.
It doesn't seem to be affected by any real movement of the bot... just this random spinning.
Do we have a bad Gyro? Or is there something we were supposed to do to make it work for this year's code?
Unread 09-02-2010, 21:17
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Gyro spinning while stationary
Try calling Gyro:Reset in Begin or sometime you know the robot is not moving. This will re-set the centerpoint.
Kettering Motorsports
Unread 09-02-2010, 21:27
FRC #2521
We have been able to re-set the center point, it doesn't stop it from spinning.
It's like the second hand on a clock (only much faster), you can forcibly move it back to 12 but it will continue spinning at the same rate regardless.
Unread 09-02-2010, 22:16
apalrd's Avatar
More Torque!
VRC #3333
Probe the output of the gyro using a multimeter. What does it say? It should be somewhere between 2 and 4 volts. If it is 0 or 5 then that is your problem.
Did you insert a wire backwards? That could cause problems.
Is the gyro powered? That could also cause problems.
Is the analog board powered? see above
Make sure you only reset it when you are not moving, and don't move it when booting up. If you might have been moving it while it was on, reboot it and try again without moving it. I have no idea when it actually sets the centerpoint, as that is protected code that is not accessible to teams (it runs on the FPGA), but I would assume it does this on Reset and startup. When it does get the centerpoint, it will think anything + or - of that centerpoint is movement, so if it was moving when it got the centerpoint it will now think that stationary is movement.
spinning kickers Da Kid Rules/Strategy 7 24-01-2010 00:38
IFI Traction Wheel stationary? Kilroy0846 Technical Discussion 10 31-12-2007 16:11
Spinning Cylinders Rick TYler Technical Discussion 5 04-02-2006 02:36
Stationary robots? Alex Burman Rumor Mill 13 21-12-2005 23:22
Stationary Goal Reinforcement Dr.Bot General Forum 8 20-02-2004 08:12
