Go to Post it is not as hard as it looks, but thats prolly cause we havent tried to build it yet... - robolemur1236 [more]
Unread 09-02-2010, 21:57
Re: Robot Crashes with voltage spike
Ninja,
What you describe is a classic example of all four CIM motors in stall causing the battery terminal voltage to fall to the point at which the Crio power supply no longer supplies the 24 volts and the Crio resets. You are using the +24 volt output on the Power Distribution board to feed the Crio right? Likewise you are also using the +12 volt output to feed the wireless adapter on the robot?
If I understand your question, you also experience the same problem with no motors connected? You don't have the Jaguar outputs cross connected do you? Have you checked to see if you have any electrical connections to the chassis? Try checking with a VOM by first removing the battery, then measure between the robot frame and the positive and then the negative lead on the PD. You should measure at least 10000 ohms depending on the humidity and in most cases well in excess of 1 meg ohm. It is possible that somewhere you have two outputs shorted to frame (perhaps through the camera mount) and under just the right conditions, you are shorting the battery.
Festo Wiring with a spike drewjones13 Pneumatics 10 10-04-2008 07:29
Using a spike with a VEX controller? AdamHeard VEX 2 20-11-2007 10:26
Lowering the voltage on a spike Mr. E Programming 16 27-02-2007 17:41
using SPIKE relay module with Fisher Price motors 1574aviad Motors 4 27-01-2005 01:49
Window Motor With Spike/Victor supergrover Control System 9 30-01-2004 15:38
