Go to Post Based on my experience coaching basketball and robotics, there is no doubt in my mind that if a sports coach receives $x then a robotics coach should, too. - dtengineering [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 09-02-2010, 22:01
Wildcat's Avatar
Wildcat Wildcat is offline
AKA: Jeff
Team Role: Scout
Wildcat is a jewel in the roughWildcat is a jewel in the roughWildcat is a jewel in the roughWildcat is a jewel in the rough
Rookie scouting coordinator requesting input
I'm a rookie scouting coordinator for my team this year, and seeking input and/or some constructive criticism on my scouting system ive developed for this year. Attached are the sheets ive made for my team to do their scouting, both match and pit. My system involves randomly pairing up my team members with each other, then randomly assigning them teams that they have to fill out a pit scouting sheet for. Then that same pair of people will randomly be assigned certain matches that they have to scout during and a specific alliance station they have to scout for where they will fill out a match scouting sheet (attached below) based on the directions (match scouting sheet directions) The match assignment sheet i have attached should help to better show what i am trying to explain. any input would be very helpful, thanks
File Type: pdf 2010 Match Scouting Sheet directions.pdf (110.3 KB, 145 views)
Unread 09-02-2010, 22:22
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: Rookie scouting coordinator requesting input
the scout sheets look very nice and professional... one thing that i recommend is that you make the playfield diagram a little bigger... i was a scout for my team last year and i found using a small field diagram can be a little tricky... looks good though...
Unread 10-02-2010, 07:07
Wildcat's Avatar
AKA: Jeff
Team Role: Scout
thats what some of my team members told me as well, but ive stretched the field diagram as far as i can while still keeping it to one page
Network switch: $25
Gas, drinks, and pizza for a road trip to Troy:$50
Mountain Dew, Nachos, and Pizza at States:$200
Being a member of the Scouting Team: Priceless
2010 & 2011 Scouting Coordinator
2010 Back-up Driver (2-5)
Unread 10-02-2010, 07:49
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Also on your match scoring sheet I would add a spot for match number. Looks like a great start so far!
Unread 10-02-2010, 08:00
Wildcat's Avatar
AKA: Jeff
Team Role: Scout
updated version of my match scouting sheet
Network switch: $25
Unread 10-02-2010, 10:51
second one looks much better... good luck this year
Unread 10-02-2010, 11:33
Techgirl675's Avatar
Techgirl675 Techgirl675 is offline
FRC #0675
Techgirl675 will become famous soon enough
Send a message via AIM to Techgirl675
It like a great system depending on how many people you have to help you scout. Last year we had papers to fill out with a similar amount of information and we had to have quite a few people helping along with our scouting team to be able to fill it al out, so as long as you have enough people you should be fine. Nice job!
"You're doin it wrong!"
http://techhighteam675.com/
Unread 10-02-2010, 12:43
Jessi Kaestle's Avatar
Jessi Kaestle Jessi Kaestle is offline
FRC #1712 (Dawgma)
Jessi Kaestle has a brilliant futureJessi Kaestle has a brilliant futureJessi Kaestle has a brilliant futureJessi Kaestle has a brilliant futureJessi Kaestle has a brilliant futureJessi Kaestle has a brilliant futureJessi Kaestle has a brilliant futureJessi Kaestle has a brilliant futureJessi Kaestle has a brilliant futureJessi Kaestle has a brilliant futureJessi Kaestle has a brilliant future
For your Pit scouting I think you captured most of the relevant information except for Autonomous Period. If you added a section asking what Autonomous routines the team had that would round out your sheets.
The other issue I had with your Pit scouting sheet is the part where the team signs off on the sheet. What was your reasoning behind asking for that?
As for your match scouting sheet the information is extremely subjective. I have found in the past that if the scouting sheet is too subjective than you cannot determine a realistic account of what the robot can and cannot do.
What I would suggest is for the match scouting sheet come up with some more questions that ask for objective results (# Balls scored, # balls kicked, etc...)
See first, think later, then test. But always see first. Otherwise you will only see what you were expecting. Most scientists forget that. - Douglas Adams
Unread 10-02-2010, 12:52
Wildcat's Avatar
AKA: Jeff
Team Role: Scout
1. autonomus is not included on the pit scouting sheet because last year when i was working with the scouting team instead of leading it i found that we would get inaccurate descriptions (if any) for autonomus.
2. the signature is there in an attempt to crack down on people that slack off and do not do their pit scouting because last year the scouting team would hand out clip boards with blank forms and get them back with the same blank forms. At the worst, mentors from my team found clip boards with blank forms scattered around the arena.
Network switch: $25
Unread 15-02-2010, 18:47
Wildcat's Avatar
AKA: Jeff
Team Role: Scout
.pdf version of the scouting presentation i plan on giving to my team, any thoughts?
File Type: pdf Pit and Match scouting presentation PDF version.pdf (678.6 KB, 68 views)
Network switch: $25
Unread 15-02-2010, 18:54
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Autonomous header is spelled wrong. Thought you ought to know.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 15-02-2010, 18:59
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
I agree what was said before with the subjectivity to your match scouting sheet. If you make it easy and just allow the scouters to just circle things like did the robot hang? yes/no. how many balls kicked? ___ how many balls scored? ___ any penalties? yes/no final score blue____ red____, etc.. This will give you better data for alliance selection and will make it easier and faster to filter through than, this robot moved forward in autonomous and then they moved around and kicked some balls and then they did this and then they did that then they tried to hang, overall I'd say this was a good robot.... numbers are better than peoples opinion and if you give a set place where the numbers will always be it will allow everything to be accumulated faster when you want stats on a team and stuff for matches and alliance selection
2012-2016 Wave Robotics Team 2826
Unread 15-02-2010, 19:10
Wildcat's Avatar
AKA: Jeff
Team Role: Scout
thanks for the catch
thats what my original draft of the sheet was like, mentors from my team wanted it more open-ended for strategy purposes
Network switch: $25
Unread 15-02-2010, 19:11
Lead Programmer
AKA: Socks
Maybe combine both then? Circles + numbers with room for explanation?
Unread 15-02-2010, 19:13
Wildcat's Avatar
AKA: Jeff
Team Role: Scout
there was something like that on the sheets last year, from my viewpoint working with the scouting team last year it did not work out very good
Network switch: $25
[IMG] code is Off
requesting professional development points? cjohnson National Instruments LabVIEW and Data Acquisition 1 23-02-2009 02:40
Robotics Coordinator for School District Coach Norm Robotics Education and Curriculum 4 23-12-2008 14:03
Requesting Parts from Igus neoshaakti General Forum 4 27-01-2008 20:08
Requesting Inventor Files Dylan Gramlich Inventor 3 05-11-2006 00:56
2.5 is alive !!!! (input ! .. more input ! ) Lloyd Burns Programming 2 14-01-2003 19:15
