Re: Need help w/ moving Camera Servo motors.
The valid range of values for Servo Set Position is from 0 to 1. If you try to set the servo position to something greater than 1, it will be coerced to 1. If you try to set it to something less than 0, it will be coerced to 0. Does that help explain what you're seeing?
| HELP- Need Globe Motors ASAP | Brandon Holley | General Forum | 0 | 03-11-2009 10:37 |
| need help with motors | EagleMentor | Programming | 3 | 06-02-2009 17:37 |
| Need help with mini motors | R.C. | Motors | 11 | 03-07-2008 16:25 |
| help getting servo values from camera | ruddy | Programming | 12 | 30-11-2007 23:18 |
| Window Motors. Need help!!!! | Mohsin | Motors | 1 | 27-02-2004 13:05 |
