Go to Post This is far more then any little school extracurricular, this is a FIRST Robotics Team. - onecoolc [more]
Unread 08-02-2010, 15:24
koo_04 koo_04 is offline
FRC #2493
koo_04 will become famous soon enough
LabVIEW project crashing
I am using the driver station.EXE on Developer. It is finding the robot and everything just perfectly fine.
My problem is that now when I try to debug the program I am using, the program crashes and just stops at a standstill. When I probe the wires and junk, it just shows no data going. Like it stopped it self. I had it working a few days ago without any problems. I have not changed the code at all since then.
The driver station says the code is there and working, but LabVIEW says otherwise... Please help!
Unread 09-02-2010, 17:34
FLash_NI FLash_NI is offline
FLash_NI is an unknown quantity at this point
Re: LabVIEW project crashing
Hi koo_04,
Do you have the latest update of the driver station?
Do you see the same result when you run the basic 2010 Game Robot Project from the Getting Started screen from LabVIEW?
thanks
FLash
Unread 09-02-2010, 19:59
FRC #2493
Okay, so I went through some very long and tedious debugging.
I found out that it only crashes when I try to add anything that has to do with the analog stuff. I added 4 analog in's (With references) to the "Begin.VI," and some to the "Finish.VI."
I created a new project and restarted from scratch and ran every step I added something. When I added the analogs, it dies. Anywhere and any how I add them. Any clues why?
Unread 09-02-2010, 22:49
StephBrierty StephBrierty is offline
NI Academic Program Manager
AKA: Stephanie
no team (NI)
Team Role: Marketing
StephBrierty is an unknown quantity at this point
You might want to call into NI support for this in case it is a bug we'll want to get it fixed ASAP and if its something solveable it'll be much easier to do over the phone. Number and times are below. Thanks!
Married to 141 Alum ('97-'00) and 461 Mentor ('00-'03)
1-866-511-6285 for
- Phone Support from Applications Engineers (1-7pm Central)
- Buying extra cRIOs
- Returning your cRIO for repair
ni.com/first
Email me
You haven't given us a lot of information to go on. Can you show us an example of where and how you added them? Maybe there's something you're doing that isn't how the analog library expects it to be done.
Unread 10-02-2010, 00:19
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Have you checked that the analog modules are completely plugged in?
Have the devrefs been opened with an "Analog Open" VI, not a constant?
-- Marshal Horn
Unread 10-02-2010, 01:59
Just to add for the information requests, please define crash. If you have a dialog or message, what does it say, when did it come up. Sometimes a picture is very helpful. If no dialog, does the program go away, what do the buttons on the panel look like, etc.
Also, if you believe that it is Analog that is an issue, you may want to try an example that does analog.
Again, it may be best to contact support.
Greg McKaskle
Unread 11-02-2010, 16:25
FRC #2493
I am not getting any errors at all. That is my issue. This is the steps I take after adding the analog stuff.
Start driver station.exe
Temp Deploy code (press play at the top)
I probed some stuff to make sure it was working. It was.
I pressed enable on the DS.
All my probes then stopped working completely.
I also did the same thing in the debug watching thing. (The light bulb). It stopped running after the 2nd loop, after clicking "Enable." All the little dot indicator things (dots that run along the steps) just stopped moving. I get no error messages and I am still able to stop the program (Clicking stop at the top) and re-do it all over again. So it is not the LabVIEW program itself.
Unread 11-02-2010, 16:34
Press play at the top of what, exactly?
You need to run the Robot Main vi in order for the program to execute properly. If you just run Teleop.vi, or anything other than Robot Main, it won't work.
Unread 11-02-2010, 18:59
FRC #2493
At the top of Labview. I will get pictures up when I can. We only work on the robot 3 days a week.
I am using Robot Main.
Unread 11-02-2010, 23:04
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Uploading the code itself would work as well.
-- Marshal Horn
Unread 12-02-2010, 02:17
This is why I asked what the crash was. If you can still click on buttons in the LV editor, it is not crashed. If it responds and the code on the cRIO stops running, then it also was not crashed or hung.
If it repeatably stops doing what you want when the program reaches a certain point, perhaps you should inspect that code, post a picture and ask questions about it. If that code does something timed such as delay for 60 seconds, and if it does it during the teleop loop, that would explain your symptoms.
Greg McKaskle
Unread 15-02-2010, 00:25
FRC #2493
Okay, so after some frustration attempts, yelling, and asking the program to work. It still did not work... BUT I gave up and started from scratch with a new project and after a while it started working again.
For now, I believe the problem is solved. If I end up running into this problem again, I will be back with more details and such.
Thanks for the help, you guys are awesome.
I hope to be much better with labview at some point in time soI will be able to help the people who run into problems like this also.
Thanks again.
Vision Code crashing flameout Java 1 26-01-2010 21:27
DS crashing ThisAintJeff FRC Control System 3 14-12-2009 14:48
Help with Personal labview project ZInventor NI LabVIEW 5 02-03-2009 09:00
Crashing the Internet MattK Chit-Chat 17 03-05-2003 12:28
Max Crashing SGK 3D Animation and Competition 11 02-02-2003 20:51
