Thread Tools |
Rating:
Display Modes |
Re: 2010 FRC camera vision tracking delay, image processing lag
that is a correct assumption, the dashboard draws the arcs.
I have a random question, is there a maximum number of tasks I can start on the cRIO before it freaks out? |
I've read that the maximum number of tasks is limited only by the amount of memory installed on the cRio. Since the cRio is running an embedded operating system, my guess is that very bad things happen once the memory is full.
That would depend on the task being created. Each task allocates a stack and some other memory. My guess is that a hundred is fine and should be enough.
I'm pretty sure that LV allocates dozens. If you have other needs, please post. Greg McKaskle |
| 2010 FRC Camera Live Feed Lag | ideasrule | Programming | 23 | 11-02-2010 02:33 |
| 2010 Camera and vision problems. | s133p | Programming | 76 | 08-02-2010 21:35 |
| Vision Tracking Camera picking up too much... | taoistconvert | Programming | 8 | 24-01-2010 22:19 |
| [not-FIRST] Camera Image Processing | Greg Marra | Programming | 11 | 11-03-2008 21:10 |
