Go to Post I swear, at IRI, Gary and I only talked about coming up with a plan to do away with Billfred, we didn't actually do anything... yet... - MissInformation [more]
Unread 10-02-2010, 02:40
javawizard javawizard is offline
FRC #3334
javawizard is an unknown quantity at this point
cRIO failing to respond to uploads after updating NetBeans plugins
We recently updated the NetBeans plugins we're using. The first time we went to upload some new code under the new NetBeans plugin, it went to the "Waiting for cRIO to restart (1s)" thing, which it's never gotten to before (it would always get stuck at "Setting up for RUN" whenever we'd upload anything, and we'd simply do a hard reboot and our program would run). It sat at there until "Waiting for cRIO to restart (500s)", at which point I decided that 10 minutes of waiting meant there was something up. I hard-rebooted and went to re-upload code, and it get stuck at exactly the same screen. Wne I hard-reboot the robot, it shows that there's robot code according to the driver station, but nothing at all moves when I activate it (although the watchdog doesn't complain about not getting fed). It occasionally goes to "No robot code" after that until I hard-reboot both the robot and the computer.
Anyone have any ideas what's going on? Since we're to the point that the rest of the team needs the electronics up to test out most of the other stuff, this is a somewhat large roadblock.
Unread 10-02-2010, 14:59
spartango spartango is offline
FRC #0192 (GRT)
spartango is an unknown quantity at this point
Re: cRIO failing to respond to uploads after updating NetBeans plugins
Make sure you have the latest cRIO image: http://ftp.ni.com/support/labview/FI...2.0for2010.zip
Unread 11-02-2010, 15:29
Daniel Jones Daniel Jones is offline
AKA: Hanes
FRC #0190 (Gompei and the HERD)
Daniel Jones is on a distinguished road
We found this behavior as well. Change your subnet mask on the network interface going to the crio from 255.255.255.0 to 255.0.0.0 and see if that fixes it.
"there are 10 types of people in this world, those who understand binary and those who don't"
REMINDER : NetBeans not talk to the CRIO cilginbilgin Java 1 08-02-2010 16:14
NetBeans not talking to the cRio scottbot95 Java 21 07-02-2010 14:19
Downloading code: Netbeans does not reset cRIO ellisk Java 8 31-01-2010 19:02
Can't load Netbeans Plugins 1195mentor Java 5 23-01-2010 07:43
Netbeans 6.8 Ftp to cRIO communication issue mark.amber Java 4 20-01-2010 17:10
