Go to Post Not everything has to be cashed in or has to have instant recognition. Sometimes being a part of a program of value and opportunity is enough. And, what you put into the program is what you get out of it. - JaneYoung [more]
Unread 10-02-2010, 07:04
craigskiles craigskiles is offline
FRC #3149
craigskiles will become famous soon enoughcraigskiles will become famous soon enough
<R01> What would be rejected?
<R01> says, "Teams must be very careful when incorporating springs or other items to store energy on their ROBOT by means of part or material deformation. A ROBOT may be rejected at inspection if, in the judgment of the inspector, such items are unsafe."
Our team has a simple spring loaded arm that delivers a grappling hook to the tower bars. The arm is deployed by lifting it out of its cradle thus allowing bungee cords to pull its several sections into line. The action of the arm during deployment is very rapid and would be a danger to anyone standing close by.
However, out on the playing field I don't think the arm is much of a danger.
Does anyone know from past experience how the inspectors would view such a device as this arm?
Unread 10-02-2010, 07:11
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: <R01> What would be rejected?
As an inspector, for BMR, I would like to see that there is no way it can be accidently deployed. You should come up with a way to make it safe, at all times, until it's on the field.
Just my $.02
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 10-02-2010, 08:18
Electrical Engineer
Rookie Year: 1995
You should add a safety pin to the latch mechanism. What do I mean by that?
Look at your school locker or gym locker. It has a handle that slides/moves up to open the locker. It also has a hole in the handle to accept a padlock. When the lock is in place, the locker can not be opened.
The deployment mechanism on your arm should have some similar safety mechanism so that it can not be deployed by mistake in the pits or being placed onto/off of the field. This safety pin/mechanism is removed as the very last action you do after you have placed the robot on the field for a match. It is also the first thing to go back onto the robot when removing the robot from the field.
Good Luck,
Mike
Mike Betts
As easy as 355/113...
Unread 10-02-2010, 08:31
Craig,
If an inspector suspects a mechanism is unsafe he/she should ask to see it in action. If it is a danger to anyone standing nearby, then it is up to you to instruct the inspector that the demonstration should take place in a safe area. If your robot makes it onto the field and someone out there sees a problem they will contact the LRI to check and correct as needed. there are several rules that you need to double check before you decide to include such a mechanism. Team update 9 has some interesting language on "out of bounds".
What would you do... stuffssguy General Forum 8 22-02-2008 20:36
what what would you like to see in a team website? fimmel Website Design/Showcase 24 08-11-2006 08:32
De Anza Rejected Kevin A FIRST-related Organizations 2 23-12-2003 21:14
What would you do? Deej General Forum 8 25-11-2002 12:43
We Rejected Wild Stang archiver 1999 5 23-06-2002 22:15
