Go to Post Your wheels look delicious. - Alexa Stott [more]
Unread 10-02-2010, 08:47
rytcd rytcd is offline
FRC #3140
rytcd is an unknown quantity at this point
kicker
hey, would a pneumatic pendulum style kicker be more powerful than a straight horizontal pneumatic punch? also, might it be better to use a kicker with a smaller surface area?
Unread 10-02-2010, 09:53
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
Re: kicker
That is a tough question to answer as there are many variables. Desired ball velocity, cylinder size, total air flow (Cv of valve or valves), mass of the kicker, etc. all interplay with each other.
With unlimited air flow, a horizontal punch would deliver the higher force. However, you may not need to deliver 100 pounds of force to the ball to get it to move the way you want. Speed may be more critical than force. If so, then the pendulum will give you more speed at the cost of some force.
Here are a few formulas:
1) (1/2)*acceleration*time^2 = Distance (assuming uniform acceleration and initial velocity of zero)
2) acceleration*time = velocity
Rewriting the second equation you get acceleration = velocity/time
Substituting that into the first equation and simplifying you get...
(1/2)*velocity*time = Distance
Rearranging you get to
3) Time = 2*Distance/Velocity
What speed do you want the ball to travel? (I'll assume 15 ft/s)
How much distance do you have to accelerate it? (Assume 3" inside frame + 3" under bumpers = 6" or 0.5 ft.
Plugging these numbers into equation 3 you find that time of acceleration should be close to 0.05 seconds. Putting this back into equation 2 and solving for acceleration you get acceleration = 15(ft/s)/0.05s or 300ft/s^2.
Divide the acceleration by 32.2 ft/s^2 (force of gravity) and you find the acceleration is 9.3G. Now the weight of a soccer ball is about 0.95 pounds. But to accelerate at 9.3G you have to multiply (0.95*9.3) and you find the force to accelerate the ball to 15 ft/s in 0.5 ft is averaged out to be just 8.9 pounds of force.
Of course I pulled the velocity off the top of my head and you may want to use less total distance. Actually, it would be safe to assume the ball does not stay in contact for the full stroke.
So use the equations, not the numbers and good luck!
Unread 10-02-2010, 10:09
thatoneguy23's Avatar
thatoneguy23 thatoneguy23 is offline
Fiding everything we need to know.
FRC #2389 (Oklahoma STORM)
Team Role: Scout
thatoneguy23 is on a distinguished road
Re: kicker
We tried both, and our pneumatics were either not strong enough to get the ball rolling, or not fast enough to extend. so, i would not go with straight pneumatics.
I think, therefore I am lost....- Me
"The difference between me and the rest of the world is sanity. They have it, I don't"
Unread 10-02-2010, 10:21
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: kicker
Make sure you're not using flow-control that are mostly shut... smaller diameter pistons will also fill and deploy much more quickly.
Unread 10-02-2010, 11:11
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
Re: kicker
By using a smaller surface area you will be losing an unnecessary amount of energy to ball deformation
Unread 10-02-2010, 14:56
terryo terryo is offline
AKA: Terry O'Brien
FRC #1784 (Litchbots)
terryo is an unknown quantity at this point
Re: kicker
HI- we are using the pneumatic pendulum-with-surgical tubing spring assist, and it's working very well. The cylinder extends the spring, and then releasing the air lets the spring pull the pendulum forward to kick the ball.
It took a bunch of testing to get the spring force vs. exhaust flow correct on the cylinder- we had to use (3) valves in parallel coupled to a manifold on the cylinder in order to evacuate the cylinder quickly to take get good speed from the surgical tubing to kick over the bump. The other end of the cylinder has no fitting and vents to atmosphere.
The interesting side effect is that we are able to fire the valves 1 or 2 or 3 at a time in order to control the kick distance (scoring, passing, or over the bump). Now it's up to the drivers to remember which button to push!
Good luck!
Unread 10-02-2010, 18:09
dtengineering's Avatar
AKA: Jason Brett
Re: kicker
We tried both pneumatic/elastic pendulum style kickers and a pneumatic/elastic linear "puncher".
The pendulum worked better for us, as we could get a bit more "loft" on the ball by contacting the ball with the pendulum beginning its upswing.
The horizontal "puncher" despite having an angled front edge to try and give the same effect, just didn't give us the "loft" we were looking for.
The pendulum design also made it easier to increase leverage, allowing the kicker to move faster despite the speed limits imposed by moving air out of the pneumatic cylinders.
So, based on our testing, we have concluded that the pendulum is a better way to kick. Your mileage, of course, may vary.
Jason
Unread 13-02-2010, 10:59
Safety3rd Safety3rd is offline
FRC #3140
Safety3rd is an unknown quantity at this point
Re: kicker
Good luck!
i love that idea cus we're using the horizontal and the ball is moving to sluggish to do anything with it. can u post a picture of you pendulum?
Unread 13-02-2010, 22:22
Vermeulen's Avatar
Vermeulen Vermeulen is offline
I have too much free time now
AKA: Tom Vermeulen
FRC #1306 (BadgerB.O.T.S.)
Vermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to all
Re: kicker
We tried a straight pneumatic kicker earlier in the season, and it was too slow, and had too little power to get the ball over a bump. Pneumatics aren't the best at speed, since there is only so much air that can go through the valves. What pneumatics are good at, however, is pulling or pushing power. We're using a pendulum with elastic bands to power the kick, and pneumatics to reset it, and it seems to work fine. However, we now have 10 days until ship date, so this isn't the time to redesign your whole kicking strategy if you already have a functional kicker.
Congratulations Ben Senson on winning the 2012 Wisconsin Regional Woodie Flowers Finalist Award!
2012 Wisconsin Regional Semifinalist
2012 Wisconsin Regional Engineering Inspiration Award
2011 Wisconsin Regional Innovation in Control Award
2010 Wisconsin Regional Chairman's Award
2010 Wisconsin Regional Quarterfinalist
2010 Curie Division Quarterfinalist
Unread 14-02-2010, 07:37
AKA: Terry O'Brien
Re: kicker
I don't have a completed pic since we're migrating mechanisms from the test rigs to the real bot, but here's an partially installed unit. I'll repost when it's finished.
kickerpic1784.doc
Unread 16-02-2010, 15:24
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: kicker
We have changed our design so that we can draw back the kicker with two big pistons, then latch the kicker (it's spring loaded) and then deploy the pistons so they're out of the way, release the latch, and BOOM! Big kick, lots of speed, and (I hope) bullet proof reliability.
PM me and I'll see if I can take some pictures...
Team 61 Kicker KC1AJT Robot Showcase 0 02-02-2010 18:30
Kicker Help? infocus Technical Discussion 23 30-01-2010 15:28
2495's Kicker Brandon_L Robot Showcase 8 28-01-2010 20:16
Hybrid Kicker falconmaster General Forum 15 20-01-2010 14:27
