Go to Post Prove me wrong. :) - Kris Verdeyen [more]
Unread 10-02-2010, 14:11
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Re: Bad Battery Example
Hugh,
That is a bad battery. It sure would seem that there is something going on internally as well. I have seen the two volt drops before, but I have not experienced the rise that is shown. It would seem that maybe some internal heating is shorting something then opening again. Is this battery less weight than a new one? I often wonder on a battery with curves like this, that maybe some venting has occurred in the past and the plates are not fully covered by electrolyte. Is it warm as you run the test?
Al,
It is an old Exide battery from 2006. I had a student running the test and I just saw the report when he was finished. Would you like the battery? If so I may still be able to recover it and send it to you. We will check the vents to try to determine if any are open or damaged. There was no evidence of obvious electrolyte leakage.
DashboardDemo Example DanDon NI LabVIEW 10 08-01-2009 21:04
BIg Bad Bob's Big Bad Claw Ty Tremblay General Forum 0 24-02-2008 18:05
How "bad" are motors with "bad" stickers? cooknl Kit & Additional Hardware 20 12-01-2005 10:33
bad battery charger clips Mike Ciance Electrical 8 19-04-2003 21:06
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
