Go to Post I believe with every fiber of my being that Engineering is an Art. It is a beautiful, wonderful, delightful art. - Joe Johnson [more]
Unread 10-02-2010, 14:45
kennypu kennypu is offline
FRC #2467
kennypu is an unknown quantity at this point
Re: absolute minimum for displaying image on dashboard
Originally Posted by Radical Pi View Post
Check the console for errors. If the camera is called for an init before the camera is fully booted then the vision code crashes.
when the axis camera has a solid green ring, that means its fully initialized correct? It is always like that so I'm assuming that the initialization is not the problem. I will check the errors though.
EDIT:
I still cannot get the camera to work. first of all, is it possible to access the camera through browser (192.168.0.90) if its connected to the cRIO, and classmate connected to cRIO through the wireless bridge?
secondly, when the cRIO and axis cam is connected, I don't see any activity in the ethernet port. The bridge's port shows the green and orange LEDs going wild, but for the axis cam, there is no light at all. Is this normal? or should there be some type of activity.
Displaying Camera Image in C# Dashboard PranavSathy C/C++ 12 08-02-2010 17:06
Labview Dashboard not displaying camera. GunfighterJ NI LabVIEW 1 02-02-2010 19:20
Reinstall of dashboard doesn't fix camera image streaming ellisk Programming 2 20-01-2010 08:04
Absolute beginner looking for resources saberflare General Forum 3 16-11-2007 10:35
Minimum Gauge Wire for Sensors? psquared89 Electrical 2 05-02-2006 15:26
