Go to Post it's possible, based on his widespread approval, that Frank is in fact a collection of kittens in a human suit - Andrew Schreiber [more]
Unread 10-02-2010, 14:59
greatman05 greatman05 is offline
AKA: Chavez Clemons Jr.
FRC #2224 (Phoenix Phenoms)
greatman05 is an unknown quantity at this point
Send a message via AIM to greatman05 Send a message via MSN to greatman05 Send a message via Yahoo to greatman05
Question Retracting a cylinder?
Hello. I was thinking about this for a while, and I'm still kind of stuck as to how it works. I've heard that it's possible to retract a cylinder without using some kind of motor "rewind" mechanism; is this true? Also, how does the programming for this work? This might not be the right forum for that last question, but does this mean that the button I program it to will have to be held down for the cylinder to fully extend, and then once it's let go, the cylinder automatically retracts?
Unread 10-02-2010, 15:00
Re: Retracting a cylinder?
It is. You fire the other side of the solenoid valve, which sends air into the other end of the connected cylinder. Programming depends on whether a single or double solenoid is used.
Unread 10-02-2010, 15:06
We planned on using double solenoids for the two cylinders we're going to use. Does the last question I asked earlier work for those, or is there something special I need to do?
Unread 10-02-2010, 15:14
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
The Festo solenoid that you recieved in the KOP is not a 'double solenoid'. It is a 4 way solenoid designed to control both the extension and retraction of a cylinder. While it can be used to control the extension of 2 cylinders (firing opposite) it won't be able to retract them.
___________________
- Tennyson, Ulysses
Unread 11-02-2010, 13:48
We're using the SMC solenoids.
Unread 11-02-2010, 15:24
Racer26 Racer26 is offline
Look at the attached picture:
Pressure goes in at P.
If you energize one side of the double solenoid, pressure flows from P to A, through the cylinder actuating the cylinder in one direction, then from B to EB.
If you energize the other side of the double solenoid, pressure flows from P to B, actuating the cylinder in the opposite direction, and then from A to EA.
cylinder count windell747 Pneumatics 17 21-01-2010 16:13
Cylinder Question Spiders Pneumatics 7 06-04-2008 11:38
pneumatics cylinder Shomron1690 Pneumatics 2 29-01-2007 13:41
Retracting power wiring ? mdatkins Electrical 5 09-02-2005 07:50
Drawing on a cylinder yamo18 Inventor 2 22-01-2004 22:23
