Go to Post I am a firm believer that there is no model that can be transplanted/copied from one team to another and have the same level of success. There just isn't a formula for it. The mindset you should have is: "I know I have made a positive impact on my community". - tim-tim [more]
Unread 09-02-2010, 23:40
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Custom Controllers
Does anyone know if someone makes custom controllers that hook up via USB (as opposed to using the Cypress and the Breadboard) If someone could make one can you give an estimate on cost and time to deliver (and reliability). We need 8 push buttons (auto release) and 3 flip switches (or three buttons that stick when pushed then release when pushed again).
Or if all else fails how do I wire the cypress.
We could use one of the attack 3's that's what we have the program running off of.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 10-02-2010, 09:50
Racer26 Racer26 is offline
Re: Custom Controllers
Why not use the cypress, seeing as thats exactly what its designed for and the reason it was included in the kit?
Also, if you wanted to, you could use a device such as a PIC18F4550 to build your own USB controller based around the Joystick HID class. I'm not sure if this is allowed by the rules or not though. The PIC18F4550 is available from a number of sources for ~$5 per part. This is advanced microcontroller stuff though, and a bit beyond the scope of FRC.
Unread 10-02-2010, 15:47
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Or you could disassemble a usb joystick or usb gamepad and wire in arcade buttons.
We have purchased arcade buttons from Happ Controls: http://www.happcontrols.com/pushbuttons/5896xxl.htm
IR controllers Bsteckler General Forum 1 23-02-2008 11:07
Controllers? joshR515 Control System 1 21-02-2006 16:06
PS2 Controllers RoboMadi Programming 3 04-11-2005 16:52
speed controllers archiver 2000 5 24-06-2002 00:19
Speed Controllers... Tom Schindler Technical Discussion 4 13-12-2001 17:26
