Go to Post I read every darn page of this thread. - Paul Copioli [more]
Unread 10-02-2010, 15:48
Safety3rd Safety3rd is offline
FRC #3140
Safety3rd is an unknown quantity at this point
2wd vs 4wd.
my team and i have been discussing the use of 2wd vs 4wd. we completely outlawed the possibility of going over the bump and are redoing the frame and everything concerning mechanics, and we thought if it would be better to have just 2 wheels driven. what are the pros and cons of 2wd? how would it be good for just driving on the level carpet ground?
Unread 10-02-2010, 15:51
REVving up for a new season
FRC #2848 (All-sparks)
Re: 2wd vs 4wd.
Check out the thread another one of your team members also posted today
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 10-02-2010, 17:56
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: 2wd vs 4wd.
this is a different subject, we're discussing how many wheels are driven, not how many wheels to use.
you're probably gonna have to go over the bump at some point, but that aside, 4 drive wheels will provide a better resistance to turning force/torque/power, since you have 4 wheels turning it, putting the center of rotation more in the middle, meaning that when turning, the wheels will orbit, rather than glide, because in a 2wD, the center of rotation is off center, meaning that one set of wheels will drag, instead of orbiting around the rotational center, making it much harder to turn, even if you use slick wheels. the only reason to use 2wD is if you put omni or swerve on the non-drive set, then you can get away with 2wD, although your turning will still be a bit weird. another problem is that you can't strafe with 2wD. but, in a wide configuration, you can probably fix all these problems if you drive wheels that are diagonal from each other, but you would only be able to strafe with a full swerve drive
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
4wd or 2wd need help itay_ms Technical Discussion 7 09-01-2007 17:41
pic: 2wd Crab Strafer Vex Tytus Gerrish Extra Discussion 13 27-08-2005 02:11
2WD diagonal System Tom McCurdy Technical Discussion 11 23-01-2005 01:02
2 WD vs. 4WD vs. 6 WD robert Technical Discussion 1 19-01-2005 20:47
4wd Lisa Kit & Additional Hardware 2 03-02-2003 13:15
