Go to Post If you promote not only the growth of your own team but of other teams at other schools you are successful. - Koko Ed [more]
Unread 09-02-2010, 17:12
NinjaSpawn94 NinjaSpawn94 is offline
FRC #1647
NinjaSpawn94 is an unknown quantity at this point
What type of Solenoid Connectors are these?
We are using solenoids this year and we were wondering on what part or connector this is and how to wirer it up for the solenoid breakout on the cRIO.
Unread 09-02-2010, 17:15
Racer26 Racer26 is offline
Re: What type of Solenoid Connectors are these?
Looks to me like the connector off a FESTO valve.
As i recall, you have to connect pins 1 and 2 to power and ground. Apply power, solenoid activates.
There should be a diagram on the side of the valve showing this.
Unread 09-02-2010, 17:35
copperhead47's Avatar
copperhead47 copperhead47 is offline
AKA: Grant "gunner" T.
FRC #1647 (Lenape Regional Iron Devils)
Team Role: Electrical
copperhead47 is an unknown quantity at this point
Send a message via AIM to copperhead47
are you sure its not applying ground to the actual ground pinout and depending on if you apply voltage to either 1 or 2? thats how the solenoid works?? like- it moves 1 way if you apply volt to 1 and the other way if you apply volt to 2?
Unread 09-02-2010, 17:39
I've never seen a FESTO double solenoid. all of the FESTO valves we've received in KOPs over the years have been single action (power on makes it go one way, power off makes it return)
Unread 09-02-2010, 18:47
SovietChaoz's Avatar
SovietChaoz SovietChaoz is offline
FRC #1647 (Iron Devils)
SovietChaoz is an unknown quantity at this point
Hi I am the same guy who posted the question. Ok, after some research they are called DIN connectors but these are connected to regular solenoid valves. Not the ones that look like D-pieces or pie pieces. But there are three pins and I just want to know how to hook it up so it puts in air one way and then opens the valve to allow air to exit the piston. Any help is taken into consideration.
Unread 10-02-2010, 00:39
chadr03's Avatar
chadr03 chadr03 is offline
FRC #2582 (PantherBots)
chadr03 has a spectacular aura aboutchadr03 has a spectacular aura aboutchadr03 has a spectacular aura about
In our case we tried to hook ours up by the wiring diagram, but it did not work. I suggest getting battery or two in series if you need 24v.
Run a wire from the positive and negative poles of the battery then try different combinations. I have yet to burn up a solenoid using this method and it is quite effective. It should light up and give a noticeable click when you have it right.
Unread 10-02-2010, 14:18
Ok but I believe they are not 24v but yea I will try it later.
--GET$--
Unread 10-02-2010, 18:57
ok cool thanks i get it... i think lol. appreciate the help. so what your saying is that reversed polarities won't burn a solenoid? thats suprising news. another question is where do they get plugged into? the sidecar? through a spike relay? or into the digital I/O? I'm a member from the R/C days of FRC. this is all kinda new to me
Unread 11-02-2010, 07:47
Originally Posted by copperhead47 View Post
...where do they get plugged into? the sidecar? through a spike relay? or into the digital I/O?
You can control solenoids one of two ways. The easiest is to add two-pin connectors and plug them into a Solenoid Breakout (on a cRIO digital sourcing module in either slot 7 or 8). You can also connect them to the outputs of a Spike relay.
Unread 20-02-2010, 17:27
Thanks alot we figured it out a little while ago
--GET$--
What are these for? (cRio Gaskets) sparrowkc General Forum 6 01-02-2010 06:41
What the heck are these? waialua359 Robot Showcase 8 21-01-2009 23:33
pic: What are these parts? AdamHeard Extra Discussion 15 18-07-2007 00:40
What type of autonomous mode program are you using? SilverStar Programming 1 21-01-2004 18:48
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
