Go to Post UFH has substance. It puts the I in FIRST. - Andy Baker [more]
Unread 10-02-2010, 18:58
nadavsen2 nadavsen2 is offline
FRC #2231
nadavsen2 is an unknown quantity at this point
Bumer question...
Do the Bumpers must be 10 inches from the floor even if my chassie isn't?
Unread 10-02-2010, 19:02
Re: Bumer question...
If the bumpers are not in the bumper zone, then your robot will not pass inspection. If your chassis won't go into the bumper zone, then you need to make it do so. <R07> specifies all you would ever want to know about bumpers--well, other than the definitions of Frame Perimeter and Bumper Zone, which can be found in Section 8.2.
Bumpers out of the bumper zone are no longer bumpers; they are violations of <R16>.
Unread 10-02-2010, 19:03
_Tanto_'s Avatar
_Tanto_ _Tanto_ is offline
_Tanto_ is an unknown quantity at this point
yes ... in "The Robot" section 8.2 of the manual Bumper Zone is defined as ... "the volume contained between two virtual horizontal planes, ten inches above the floor and sixteen inches above the floor" hope this helps
"a triscuit can only do what a triscuit does"
Unread 10-02-2010, 19:25
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
yes they need to be 10-16 inches from the ground no matter how tall your robot is
Unread 11-02-2010, 04:12
FRC #2231
so i can make another "floor" of chassie in the robot that it's 10 inches from
the floor and to put on it the bumpers?
Unread 11-02-2010, 05:25
Chris is me's Avatar
AKA: Pinecone
I'm not sure I understand, but you need to mount your bumpers to some part of your robot 10 inches high. Everything in your robot needs to be within the perimeter formed by the bumpers.
Unread 11-02-2010, 06:05
FRC #2231
I mean like 2 floors of chassie that look the same , one is 10 inches high and nothing is beyond it.
something like this image:
Unread 11-02-2010, 06:30
GaryVoshol's Avatar
Cogito ergo arbitro
That image is correct, assuming the proper distances. The bumpers must be mounted so that they remain between 10 and 16 inches from the floor, when on flat ground. Since the bumpers themselves are 5 inches wide, that gives you an inch of leeway.
(since 2004)
Unread 11-02-2010, 07:46
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
They also must be fully backed by the robot frame. In your picture it looks like you are going to add post to mount the bumpers. That won't work.
M. The entire length of the BUMPER backing must be supported by the structure/frame of the ROBOT (i.e. the backing material must not be in “free space” between or beyond attachment points) (see Figure 8 – 3).
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Question Jeremy General Forum 6 13-03-2004 22:39
Question Jack FIRST Scouting Network 6 27-10-2003 22:04
Question Finch Rules/Strategy 5 11-02-2002 21:47
Question Jgreenwd1 General Forum 1 04-10-2001 15:19
